IPD sale Volvo Parts
Did you know? 🤔
OBD no signal
jantt
Year and Model: C70 2000
Has thanked: 0
Denmark
jantt
OBD no signal
Post by jantt » Sat Jan 12, 2019 10:55 pm
Hi
Have a C70 2000
When I put my scanner in the OBD then the power light is on, but not the other two lamps.
They come on as I connect it, but goes out again.
Same with the Volvo Vida. No connection.
Has worked before.
Tried to change the wire in the tunnelbox. Did not help.
Could it be a groundcable ?
wizechatmgr
Has thanked: 19 times
Been thanked: 47 times
United States of America
wizechatmgr
Re: OBD no signal
Post by wizechatmgr » Sun Jan 13, 2019 12:10 am
Would suggest checking the 12V+ and grounds that go to the OBDII connector. It is also possible one or more terminals within the connector have some corrosion built up.
1999 V70 XC AWD - ~175k miles
jantt
Has thanked: 0
Denmark
jantt
Re: OBD no signal
Post by jantt » Sun Jan 13, 2019 12:36 am
+ is allright since power light is on and + goes together with cigarligther and it works.
Has as I wrote changed wire and t is not the OBD connector socket
has enclosed picture of wiring
wizechatmgr
wizechatmgr
Re: OBD no signal
Post by wizechatmgr » Sun Jan 13, 2019 1:21 am
Next idea I would have would be to unhook the battery and reseat the ECU.
jantt
Has thanked: 0
Denmark
jantt
Re: OBD no signal
Post by jantt » Sun Jan 13, 2019 1:24 am
ok thanks. Will try that
jantt
Has thanked: 0
Denmark
jantt
Re: OBD no signal
Post by jantt » Sun Jan 13, 2019 8:33 pm
Didn`t help to unhook battery
jantt
Has thanked: 0
Denmark
jantt
Re: OBD no signal
Post by jantt » Sun Jan 13, 2019 9:48 pm
Sometimes my abs + stc lampes goes on.
Think I have read that faul on abs unit can have somrthing to do with obd. Is that right ?
wizechatmgr
wizechatmgr
Re: OBD no signal
Post by wizechatmgr » Sun Jan 13, 2019 10:00 pm
Yes, but I'm not sure most scanners other than VIDA will be able to see it. Ignition switch is in position II when you're attempting to communicate with the vehicle, correct?
jantt
Has thanked: 0
Denmark
jantt
Re: OBD no signal
Post by jantt » Sun Jan 13, 2019 10:31 pm
yes it is in II. Put the scanner in and all 3 lamps light up and 2 goes out. Turn to II and notthing happens. Then I touch the scanner and the 2 lamps comes on, but goes out again
wizechatmgr
wizechatmgr
Re: OBD no signal
Post by wizechatmgr » Sun Jan 13, 2019 10:52 pm
Any chance you can take pictures of these? I appear to be daft tonight =)
