IPD sale Volvo Parts
Weird starting issue on Vovlo S70
melmaclifeform
Year and Model: 1999 S70 Base
United States of America
Post by melmaclifeform » Sun Jan 13, 2019 6:50 pm
Ok, so I just recently got a 1999 Volvo S70 base model, and it's got a weird issue going on- it doesn't crank, but when it's jumped it'll occasionally just start right up and drive and all.
Looking through the possible issues haven't really helped, I haven't seen anyone else have this particular problem.
My guess is that the ignition switch has broken, do you guys think the same?
My reasoning is that since it starts occasionally, then the car has to think that the key is turned all the way to the III position.
RickHaleParker
Has thanked: 2 times
Been thanked: 227 times
Re: Weird starting issue on Vovlo S70
Post by RickHaleParker » Sun Jan 13, 2019 7:09 pm
Could be the Antenna ring on the fritz. The key has a RFID chip in it. The Antenna ring (the RFID reader) is that plastic ring around the key hole. It is common problem.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
melmaclifeform
Post by melmaclifeform » Sun Jan 13, 2019 7:16 pm
Hmmm, is that an easy repair? The thing that made me think it was the switch was that the key turned without any resistance, really. It wasn't like that in any of the other cars that I've driven so that might be of more assistance.
RickHaleParker
Post by RickHaleParker » Sun Jan 13, 2019 7:20 pm
It is very easy and on a '99 no reprogramming required.
melmaclifeform
Post by melmaclifeform » Sun Jan 13, 2019 7:23 pm
Awesome! Thanks man, I'll try that first
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 147 times
Been thanked: 442 times
Trinidad & Tobago
Post by abscate » Mon Jan 14, 2019 5:12 am
An antenna ring problem will leave you with a crank,no-start problem, not a no crank problem
How old is your battery and what is state of charge?
Turn headlights on for 30 seconds, turn off, then measure voltage and temperature at battery
Electrical part of ignition switch would be my first stop if you want to try parts swapping approach.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Has thanked: 43 times
Been thanked: 132 times
Post by erikv11 » Mon Jan 14, 2019 8:11 am
Agreed, it's not the antenna ring.
Obvious candidates, in order of likelihood:
(1) Electrical portion of the ignition switch
(2) Positive or B+ battery cable
(3) Battery
Since you can test the battery and the cable. All as abscate suggested.
'96 855 NA, 140k
'98 S70 NA, 205k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 275k
'06 S60 R, 155k
melmaclifeform
Post by melmaclifeform » Mon Jan 14, 2019 3:14 pm
The car is charged enough to turn EVERYTHING on as soon as the cables are connected. Wipers will go on and whatnot, all of that stuff.
I know the battery is a few years old old, but it's been tested and it is a good battery that holds a charge.
RickHaleParker
Post by RickHaleParker » Mon Jan 14, 2019 4:11 pm
Take the battery to Autozone and get a free bench test. The battery may hold a charge but not perform under a heavy load. The starter is a very heavy load ....
melmaclifeform
Post by melmaclifeform » Mon Jan 14, 2019 5:05 pm
See, even if it was the battery I think there might be more problems, it starts WITHOUT turning the key when you jump it
Who is online
Users browsing this forum: 98RedV70GLT and 69 guests
