IPD sale Volvo Parts
Heater blows hot and then cold repeatedly
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
dpayne20
Year and Model: 2006 s60
United States of America
Post by dpayne20 » Sun Jan 13, 2019 10:15 pm
Hello, The heater in my 2006 volvo s60 2.5t blows hot air intermittently over and over again. It will blow hot and then cold in periods of about 4 seconds. I have filled the coolant to know avail. any ideas would be helpful, thanks
RickHaleParker
Has thanked: 2 times
Been thanked: 184 times
Re: Heater blows hot and then cold repeatedly
Post by RickHaleParker » Sun Jan 13, 2019 10:35 pm
Check the damper and see if it is moving. For a 4 second change it got to be blending of hot and cold air. A heater core cannot change temperature that quickly.
1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4
2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000.
dpayne20
Post by dpayne20 » Sun Jan 13, 2019 10:36 pm
How do i check the damper?
RickHaleParker
Post by RickHaleParker » Sun Jan 13, 2019 10:52 pm
Up under the dash, right side. Check to see if the motor(s) are moving in sync with the temperature change and listen for internal flaps flopping around.
dpayne20
Post by dpayne20 » Tue Jan 15, 2019 1:52 pm
Ok I checked it, the arm moves a couple of times and then stopped, I tapped on the motor a couple times making another arm move a little and go back in place, now to passenger side still works great and the drivers side heat work up until the max heat notch and it goes back to goi g between hot and cold. Could it be the damper motor or is something in the way of the arms or is it a software issue that volvo could fix with a update?
oragex
Year and Model: S60 2003
Has thanked: 71 times
Been thanked: 113 times
Canada
Post by oragex » Tue Jan 15, 2019 3:42 pm
Maybe the climate unit needs recalibrated or the cabin temp sensor has a problem. This sensor can get damaged when the battery is connected without having the key in Pos II
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
RickHaleParker
Post by RickHaleParker » Tue Jan 15, 2019 7:17 pm
Does the arm movement correlate with the changes in temperature?
dpayne20
Post by dpayne20 » Tue Jan 15, 2019 7:18 pm
Yes it does
dpayne20
Post by dpayne20 » Tue Jan 15, 2019 7:41 pm
Everytime the tempature changes there is a buzzing sound in the dash
dpayne20
Post by dpayne20 » Tue Jan 15, 2019 9:01 pm
Also it seems that I can recalibrate whatever is making the buzzing sound by taking both temperature dials and putting them to cold and then going back up at the same time, but when I restart the car the buzzing starts again and it gets hot and cold along with the sound
Who is online
Users browsing this forum: dj_v70, oragex and 52 guests
