Low Beam Headlight bulb access?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 151 times
- Been thanked: 4 times
Darn it, I just went out in the driveway to replace both low beam H7 bulbs and I thought it would be easy. Instead I found a bunch of unknown wire harnesses tie-wrapped together right in front of my circular access door. Can away those tie-wraps so I can get some extra slack to even see the plug for replacement?
Mr. Detail
Is a "P2" the same thing as a "V70"? I have a '02 Base V70 wagon.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Then yes it's a P2. It's the platform name.
They're a pain to get to. Some people take the air filter housing and stuff out.. it's doable with everything in place but not easy.
I'm sure any cables that are fastened in the area used to be secured by clips that have broken and been replaced with zip ties. Just zip then back when you're done and you should be able to move them carefully.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
I ask because this is the P80 area of MVS, only up to MY 2000.
The -‘01 and newer years are very different cars.
Mr. Detail
Thanks for asking "BEJinFbk" and thank you "Rattnalle" for your response.
- BEJinFbk
If I knew squat about the newer cars, I’d be happy to throw in, but alas...
I’m trapped in 1998! And these heated seats are soooo comfortable.
Mr. Detail
Amen to those heated seats!
