2003 c70 ignition lock will not turn
hightech24
- Year and Model: 2003 C70 convert
- Has thanked: 1 time
have had problem several times when the key is inserted and the key will not turn, have had to reinsert the key several times before it would allow to turn and start the car.
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
This is well documented on this forum, it is the ignition cylinder.
a) If it will turn fine between key positions 0 and 1, then there is a good workaround fix (1 hour labor, no parts)
b) If it won't turn past position 0, you are better off replacing cylinder (part cost $200, 4+ hours labor depending on your luck with security bolts) unless you are willing to go through complete dissassembly and tumbler fix after removing it.
You want to take care of this before it gets worse! I broke down 500 miles away from home. Wife wouldn't drive car after that, had to buy new car and sell that one!!!
- 1831 Views
Last post by ggleavitt
- 22 Replies
- 1963 Views
Last post by volvolugnut
- 882 Views
Last post by Krons
- 1487 Views
Last post by joevar
- 2891 Views
Last post by Mark60
