1998 S70 Oil Cooler Lines 3528201 3528207
98S70T5
Year and Model: 1998 S70 T-5
Has thanked: 2 times
Post by 98S70T5 »
Does anyone know which side is supply and which side is return? I have one that someone did a crappy patch job on years ago I want to replace before it becomes and issue.
Thanks,
98S70T5
Post by 98S70T5 »
Scratch that, I see with some research they are connected together via a bracket. Probably makes more sense to replace together.
Thanks,
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Together is smart, yes. Kind of an awful job but good luck!
Has thanked: 1611 times
Been thanked: 4072 times
If you buy them new please put part numbers into this thread for search
98S70T5
Post by 98S70T5 »
Will do, There must be some pin holes in the lower hard line on mine. When I first picked this up from my Grandpa I noticed a small drip spot on the ground. Closer inspection showed someone had slipped some rubber hose over the line itself at some point in time and used 2 hose clamps on each end of the hose. I tightened those up and no leaks now (it's been that way for the last 13 years at least).
I will just feel better about long highway trips with fresh lines so I don't evacuate all of my oil in a short amount of time if it should fail.
Part numbers added to title
Ouch $125 each!
** Don't forget the Orings - both at transmission and at radiator - several pieces.
Thats the kind of repair that leads to blown engines
98S70T5
Post by 98S70T5 »
Yikes, thanks for the part numbers.
The aftermarket ones are reasonable but it looks like they don't have the bracket (or maybe that bracket comes off of the factory parts?).
I guess that hose has held well for a very long time though.
Post by erikv11 »
Aftermarket (e.g. Dorman) is known to be very low quality on this part. The usual way to save a bundle of money on this job is to just get the lines rebuilt at a hydraulic shop but that assumes the hard line section is good.
