I installed new lower control arms a few months ago. Last night I was under the car and noticed that I have a clearance issue with the front bracket of the control arm. I noticed wear on the control arm from the frame. It appears that the tolerance on the cast was not perfect and it is self clearancing. It is a bit hard to see in the photo below, but my question is-- should i leave this alone or should I remove the LCA and possibly grind away a bit of the frame and/or LCA so this is not happening? The picture does not show it well, but I believe that the marks are fresh as the aluminum is shiny indicating fresh wear. It is winter here and salt has been on the roads so if it was not fresh, I would have expected a small bit of oxidation on the aluminum.
To make it a bit easier to see, I did mark the area where the contact is showing.
LCA clearance at frame
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
At the rear wheels? What brand was it?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Do not grind the frame...even a little bit.
Your problem was caused by an incorrect dimension.
It could be an off-center bushing pin or collapsed bushing material.
Just do it again the right way. No biggie.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Do you still have your original LCAs? The only way to address this on the cheap, and get away with it, is to press new bushes into your existing LCA. Either genuine Volvo or OEM which I think is Lemforder. I tried Febis for the rear bush on mine because I noticed a physical design difference in the rubber that peaked my interest. So far they're holding up good but it hasn't been enough time to conclude they're 'good' as the problem with aftermarket LCA bushes on these cars is a lack of longevity and/or improper mechanical characteristics of the rubber formulation resulting in poor vehicle handling.
Georgeandkira
By doing it again the right way I did mean using quality arms or quality bushings. Sorry for the confusion.
I had polys-both front and rear-pressed into a "jump set" of control arms I sourced at a salvage yard so I could do a bunch of front end jobs in one swoop.
- mrbrian200
Poly bushes have their drawbacks also. The thing that holds me back is the need to take the LCA off the car every couple years to re-grease them. If you don't keep them lubed they eventually 'lock up' and restrict control arm movement destroying ride quality.
- oragex
+1 @mrbrianmark99tj wrote: 17 Jan 2019, 17:10 Front. Detroit Axle.
I bought the car and it failed inspection for the bushings being bad. I quickly bought a cheap set from amazon so I could get it on the road. Apparently I made a $100 mistake.
we all do mistakes, small consolation, $100 is not that expensive for a mistake
You can get parts at site such as Fcpeuro or Ipdusa. Lemforder would be a good choice, perhaps even IpdHD (not well tested long term), just select the right model of XC70, I think the CA on the XC are different that the ones on S60
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The angle of LCA suggest there is little to no upward push at the knuckle, i.e. the coil spring around the strut is at max. You want to measure and compare the distance from the fender to center axle bolt. Correct the problem. The wear at the LCA is a distraction.mark99tj wrote: 17 Jan 2019, 09:26 I installed new lower control arms a few months ago. Last night I was under the car and noticed that I have a clearance issue with the front bracket of the control arm. I noticed wear on the control arm from the frame. It appears that the tolerance on the cast was not perfect and it is self clearancing. It is a bit hard to see in the photo below, but my question is-- should i leave this alone or should I remove the LCA and possibly grind away a bit of the frame and/or LCA so this is not happening? The picture does not show it well, but I believe that the marks are fresh as the aluminum is shiny indicating fresh wear. It is winter here and salt has been on the roads so if it was not fresh, I would have expected a small bit of oxidation on the aluminum.
- 798 Views
Last post by zmf
- 4028 Views
Last post by E Showell
- 33 Replies
- 8685 Views
Last post by mrbrian200
- 1457 Views
- 1764 Views
Last post by nelaco
