Hesitating when gas is pressed
Hello I recently purchased a a 2006 volvo xc90 with the 2.5t engine. When I'm stopped and press the gas it hesitates to accelerate. The rpms go up to idk at least 2 Grand then it goes. If I'm on a flat surface, put it in drive and let off the brake it doesn't move. Once it gets going it drives and shifts like butter. Engine runs great. No hesitation if I put it in p or n and rev it. It has had timing belt done 4000 miles ago. It has also had in the past entire turbo replaced and lots of other work done to it that was reported on the car fax. It's almost like a sticking brake but I already jacked up car and made sure brakes went sticking . W mode dosent pop up on dash or anything when pressed but I already selected manual gear shift put it in first and no diffrence. just want more opinions before I dig into it as this is my first volvo
- SuperHerman
- Been thanked: 207 times
Look at your tranny fluid - your car has a dipstick. Should be a driver side front with a yellow pull handle. May be hidden by a rubber hose. What color is the fluid and is the level correct? It can be a pain to pull the dipstick tube as it has a clip that keeps it from coming out. First inspect condition of the fluid with engine cold so you don't get burned and get the idea of how to remove the dip stick. Then let it idle in park and check your level. Report back.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Also, is that the 6speed Geartronic or 5 speed Aisin? Careful when refilling these transmissions, usually done by the dipstick, not by removing some top bolt. As above, look at the fluid first (usually requires 3309 type), but if the fluid is already clear red (recently replaced), it may have an issue with the transmission
- 11 Replies
- 4157 Views
Last post by dubsetter
- 1375 Views
Last post by Anthony303
- 13 Replies
- 2255 Views
Last post by misha
- 883 Views
- 1028 Views
Last post by ranger481vs
