2006 XC70 Car won't start - [loose turbo induction snorkel ]ECM-640C ECM-640D ECM-929D Topic is solved
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Hi folks,
My XC70 AWD 2006 cannot start, but let me give you some background.
One month ago I noticed that the car was bogging down when I was accelerating on the highway, let's say, it was hesitating before getting up to the speed I wanted.
I thought it was time to replace the spark plugs which were 100K old, so last Saturday, I replaced the original Volvo sparks with the NGK 7092.
The old sparks were really worn, besides #3 #4 and #5 were soaked with oil... #2 and #5 were just worn.
I think the reason why #3 #4 and #5 were soaked with oil is because 6 months ago I realized the PCV hose was broken, I replaced it but there was plenty of oil next to the ignition coils location. I cleaned everything but I guess the oil might have gone down the threads of the sparks.
Anyhow, once the sparks have been replaced, the car started immediately and the engine sounded totally different, very smooth and clean.
Yesterday, after a few minutes I was driving the car (cold start, I am in Canada so well below freezing point right now) the engine almost stopped, as if not enough fuel was getting there, I pulled over, did not touch the throttle pedal, after a few seconds the engine rpm went up to normal again.
This morning, no start at all.
I was convinced something was wrong with the ignition coils, but the VIDA errors say something different.
I was able to start the car again one more time while I was plugged in with VIDA, the engine stayed idle for about 10 minutes, then it stopped.
I understand the meaning of the codes, but I do not know where to start from.
Any chance this is related to the spark plugs or the ignition coils or anything I might involuntarily done during the replacement?
It is difficult for me to think of a pure coincidence.
Many thanks for your advice :)
Alex
Polar 940 Turbo SW - 1997
Metallo
Post by Metallo »
Has anybody an opinion on this issue?
I think the genuine spark plugs have a 0.28" gap, do you think the gap of platinum spark plugs need to be the same??
Any way those errors can be linked to the spark plugs?
Alex
Metallo
Post by Metallo »
Hi there,
The reason of the errors was the low compression, due to my negligence, the intercooler pipe was completely disconnected on the back of the engine.
Most likely the reason is because when I tightened the clamp, I did not fully push down the hose in the connector, so it popped out.
Once I realized the issue, I was (and still I am) pissed off with myself, I am always very careful on everything I work on, in addition, I removed/re-hooked that hose multiple times in the past, never an problem... I cannot explain this stupid error.
I removed the spark plugs, made them 0.030", no oil on any on them.
Did a VIDA check, clean.
Well, I hope at least I made you laugh!
Thank you for your time anyhow.
Alex
Has thanked: 1609 times
Been thanked: 4065 times
Stumbled into this thread, and closing it off
We aren’t laughing still, Metallo
:D
