Volvo s60 2001 Drivetrain system too rich
Hii have my volvo s60 2001 2.4 petrol fwd and it's throwing the code drivetrain too rich P0172 I have not tried a new maf sensor yet, or 02 sensors, when the eml light is on it will dump fuel and when I take it off using my reader and acts normal kinda stuck help will be appreciated thanks
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Too rich means more fuel and less air than expected and as measured by the front O2 sensor.
Likely suspects are leaky fuel injectors resulting in extra fuel, perhaps very high fuel pressure, or on a 2001, the throttle may not be opening enough and so reducing the air the throttle bodies have known problems 2000 - 2001). It could also be the O2 sensor itself.
How smooth does the engine run at idle and at 2000 RPM?
Any other symptoms?
Do you have any diagnostic tools? DICE, or Torque phone app?
Any other symptoms?
- Been thanked: 4063 times
Check all your vacuum hoses for leaks first, thats most common.
Please keep your text in sentences with punctuation and paragraphs breaks per MVS Terms and Conditions.
Hey thanks for the reply, at idle 800rpm the sensor reads sometimes it dips and feels like the car will stall, but it's like really quick dips in the revs 790-800 I think, at 2000rpm it's sounds and feels normal?
Only when I leave the eml light on, if I take it off with torque pro it won't dip in rpm of course, diag tool available at the moment is torque Pro with the obd2
Should I replace the front 02? Or should I replace both 02 sensors and maf?.
Also where would one find the vacuum hoses it's under and near the power steering tank?
Look under the hood for a label showing all the hoses, usually yellow
