I bought a V50 some time ago and it's too low for the country I live in (lots of pot holes--sometimes as deep as 3-4", uneven roads, banked asphalt, snow, ice, lots of unpaved roads, etc.). I was thinking a good solution would be to lift the vehicle and put on some off-road tires.
Does anyone have any experience lifting the V50 or a similar model? How high can I reasonably lift it for it to still be safe (I was thinking around 10 - 20cm)? Any recommendations for how I should life it (i.e. which shocks I could buy)? I'm not very car saavy (yet), so it's possible that it's not even the shocks that would need to be adjusted--or replaced.
Lifting the V50?
HelloBucklebell
- Year and Model: 2005 V50
- Has thanked: 1 time
- Has thanked: 2856 times
- Been thanked: 1332 times
I checked https://www.xc70liftkit.com/ , but no, they make nothing for the Volvo P1 platform (or anything besides XC70 P2).
I'd go with tall/narrow tires to solve this... 205/65/16 or so. And reprogram the speedometer with VIDA.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Taller tyres is the only resonable thing you'll get away with without killing the suspension geometry. If that doesn't do it the sensible thing is to get an XC model.
jtopiso
- Year and Model: 2009 C30 2.0i
- Been thanked: 3 times
10 or 20cm? Thats probably more than the total wheel travel available!
If you mean 10-20mm (10mm=1cm), then I would look for a custom spacer for the spring seats. A better (and more expensive) solution would be to find some threaded body "coilovers", so you can tune the rideheight, but this are usually made for track/racing, so perhaps they won't allow much rise, and only allow to lower the rideheight.
HelloBucklebell
Any suggestions for reading material on figuring out which shocks and springs I ought to look for (and perhaps even how to install)?
HelloBucklebell
Rattnalle wrote: 28 Jan 2019, 02:08 Taller tyres is the only resonable thing you'll get away with without killing the suspension geometry. If that doesn't do it the sensible thing is to get an XC model.
Yeah that's what I'm afraid of. I'm in a tight spot with selling the vehicle though, as I can't sell it unless I take it to Lithuania to put it up for sale (Ukraine has high import fees that usually outweigh the price of the car, so people keep it on Lithuanian plates--but a new law is now requiring that residents either import the car officially or give it up).
