'96 850 Check Engine Light
JonTechno
Year and Model: 1996 850 2.4L
Post by JonTechno »
1996 Volvo 850 2.5L Automatic. 175K ish miles (Odometer intermittent). I used a Matco Scan Tool to pull the codes. 2 are shown:
PO172
P0440
Looked them up, not sure how to continue diagnosing problems.
All help or recommendations welcome and appreciated
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Hello!
Both of those point to a vacuum leak in my mind, at least. Check your hoses and replace. For the 0440, it can be an idea to go over all hoses and fittings in the evap system, and also replace the valve.
- S
[Sold] '97 S70 T5
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
In my experience, P0172 is always caused by a severe vacuum leak. Check your vacuum lines. With the engine running, you might be able to hear a wooshing or hissing sound to help you track down the leak. What rpm does it idle at?
P0440 is usually the J and L hose on the charcoal canister. Replacing the lines on the evap system may solve your P0172.
JonTechno
Post by JonTechno »
Thanks, I'll have to check the hoses for leaks, as well as the J and L hoses.
Engine idles at 1,000 RPM
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Non turbo with auto transmission and in "D" idles at 1000rpm.
While in P or N it will be around 900rpm.
N/a manual around 900...Turbos a bit lower...around 800+-50.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
