1996 850 Turbo Sedan
I'm looking for some bolts for the air guide (splash shield) #6808693 that attaches under the car to the front end. I ordered three clips from FCP, but they do not carry the bolts. There are two threaded holes under the car where the guide is attached. They appear to be M6, but the ones available from the hardware store are a 1.0 pitch, which does not thread into the holes. It appears to require more coarse threads than the ones I have.
Would anyone know the specifics on these original bolts? I've not yet tried the dealership, but I rather cut new threads with a tap than go there.
Size of Bolts for 850 Air Guide (Splash Shield)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There are 2x10mm bolts on each side:
viewtopic.php?t=80751
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I think they are 1.0 mm pitch M6, maybe you need to chase the threads?
rick4484
- Year and Model:
- Has thanked: 59 times
- Been thanked: 10 times
Thanks, I didn't think about chasing the threads. I just assumed the M6 1.0 were not similar threads. When I see 10mm, is that the hex size of the socket or wrench needed, and not the threads?
- Has thanked: 311 times
- Been thanked: 817 times
Yes, "10 mm" refers to the socket used on the bolt head. Threads are M6 1.0 as stated, just chase it.
- RickHaleParker
- Been thanked: 978 times
Bolt and head are separate measurements.rick4484 wrote: 30 Jan 2019, 09:07 When I see 10mm, is that the hex size of the socket or wrench needed, and not the threads?
Bolt referred to the part below the head.
- A 10mm bolt (M10) bolt fits in a 10MM hole
A 10mm Hex head requires a 10mm wrench
I need a ____ bolt with a ___ head. Fill in the blanks.
Active
Past
Past
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
My 1995 has course threads. The bolt is about 1/2 inch in length. It has a 10mm head. It also has a washer, about 3/4 inch diameter.
Klaus
You can swipe one of the fender bolts to replace these , if you drop into the sewer grate underneath.
Then email me and I can send you a spare by usps
