2006 Volvo S60 2.5T - MAF sensor issue
DianaPrince
- Year and Model: 2006 S60
Recently replaced the MAF sensor after rough idle + CEL + “engine system service required” message + codes P0101 and P0170. It’s been about 3 weeks and now the CEL and engine system service message are back; throwing code P0101 again. Is the new sensor I installed a bunk part? Or is this something else? Super annoying
Volvo cars I’ve owned:
1990 240 DL
2000 S70 GLT
2006 S60 2.5T
1990 240 DL
2000 S70 GLT
2006 S60 2.5T
- RickHaleParker
- Been thanked: 977 times
Possible source
1. Take some MAF cleaner, disconnect the wiring harness to the MAF. Clean the connector with the MAF cleaner. Reconnect.
2. Take a can of starting fluid and spray around the intake. If you hear the engine surge you found a leak. If you do find a leak stop spraying as soon as you hear the engine surge. Don't want to blow the engine to kingdom come.
3. Check to see if something got into the intake and is blocking the air flow. Air filter clean?
- 1. Contact resistance or oxidation in the mass air flow (MAF) connectors
2. Air leakage in the intake system
3. Blocked intake system
4. Damaged mass air flow (MAF) sensor.
Active
Past
Past
- Been thanked: 4064 times
More likely a vacuum leak than a MAF failure can you read out fuel trims on your code reader ?
- 11 Replies
- 4828 Views
Last post by matthew1
- 1842 Views
Last post by NiceGuy
- 26 Replies
- 6339 Views
Last post by ChadLee
- 14 Replies
- 11582 Views
Last post by mrbrian200
- 2851 Views
Last post by jimmy57
