Just drained some transmission fluid out and the color is almost dark like engine oil...
Who ever had it b4 me never changed it obviously...
Does this mean my transmission is gonna be messed up now??
Is there a certain order for me to run the gears in so the newer fluid blends into it
I put full synthetic and 1161540 valvoline in it...
Omg! What does the dark transmission fluid color mean?
natural4reelz
- Year and Model: 02 VOLVO S60 TURBO 5
- Has thanked: 3 times
natural4reelz
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
The fluid does get dark in these cars. I just drain, measure the amount and refill. My cars are on a once a year "drain and fill" schedule I do every Thanksgiving. I have chosen Aisin Type IV transmission oil for my fleet. Many use Mobil 3309 or Toyota Type IV.
Most people on Volvo forums use the specific oil, like I mentioned above. On websites like "Bob is the Oil Guy", there you read about people using Valvoline oil, or synthetic oil in these Aisin transmissions.
I use the oil the manufacture says to use. Gets to be a grey area about a specific oil, and a oil that's compatible. Again, I chose to use the non-synthetic Aisin Type IV.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
natural4reelz
What kind of transmission do i have and what do i do as far as what gear to put it in is there a certain order to blend this new fluid into the old
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
I don't think that color looks so bad. It still appears to have some red to it.
You mentioned some issues with the transmission. Do you have a code reader, or go to an autoparts store and have them read out the check engine light codes. Then let us know what they are.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Does it smell burnt? If not, you may have avoided serious trans problems if you begin a drain and fill program now.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
natural4reelz
I HAD a CEL CODE of PO700 And this was after i did the fluid drain and fill.....
But i deleted the code this morning like 530am LAS VEGAS, NV time and been driving it and the CODE hasnt returned.... and i didnt think it smelled burn but another friend of mine said it kinda did...
It drives fine now and has a little less pep but i hope
For the best...
When should i do another drain and fill again.... ???
For the best...
- E Showell
Some people like to put a few hundred miles on between, but you can probably do it much sooner. You want the old fluid and new to have a chance to mix to dilute the old with new.
'95 855 auto (sold)
'95 855 auto (sold)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Just driving around the block will be enough to mix the oils. So do it whenever is convenient after driving few trips. The next week or a month later really doesn't matter that much.
- 1773 Views
Last post by aaronlife
- 16 Replies
- 16931 Views
Last post by firstv70volvo
- 19 Replies
- 5810 Views
Last post by matthew1
- 15 Replies
- 2353 Views
Last post by Krons
- 585 Views
Last post by BlackBart
I took a picture of the fluid but dont know how to post it up here.....
