CD player disc error message
REnglerth
- Year and Model: 1998 xc70
- Has thanked: 6 times
I attempted to load a CD and it failed to do so. It read "disc error" and attempted to eject it. I ended up pulling the CD out with some needle-nose pliers. Now, approximately every 15-20 seconds it sounds as if its trying to eject a disc, then stops, then does it again. Any ideas?
okidiver
- Year and Model: 2015 V60 2008 C30
- Has thanked: 7 times
- Been thanked: 3 times
Yeah, something's out of alignment and pulling it out manually probably made it terminal. Chance you could pull the unit out and monkey with it--may get it aligned or slip back to the way things should be, but most likely you won't be using the CD player again.
- 10380 Views
Last post by natural4reelz
- 11339 Views
Last post by precopster
- 1306 Views
Last post by subzerocarfanatic
- 18 Replies
- 2980 Views
- 3502 Views
Last post by matthew1
