Front End Creak/Squeak
Tinwood
- Year and Model: 1996 850 GLT
I am starting to notice a creak/squeak/groan in the right front of the car ('96 850 GLT). Always when travelling over a rough surface. It has the sound of a rubber bushing or something similar. Could this possibly be a sway bar bushing or a control arm bushing? Maybe something related to the strut? How do I diagnose?
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Probably a strut mount spring seat, quite common. Take a large wrench or pliers and try to turn the large nut at the top of the strut (in the engine bay) clockwise. If it resists turning or moves back to its original position, then it is in good shape. If it turns easily, then the spring seat needs to be replaced - use a heavy duty spring seat or one for an XC90.
Klaus
- Has thanked: 311 times
- Been thanked: 817 times
When replacing the spring seat, the key is the manufacturer, not how the part is described. The XC90 spring seat and the 850 spring seat are the exact same part number from Volvo, neither is more or less heavy duty than the other. Buy the part from Volvo is still my recommendation.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Control arm bushings can also make those strange noises when they become dry.
A bath of wd-40 usually quiets them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2973 Views
Last post by JNavas
- 1841 Views
Last post by estrekal
- 11 Replies
- 2348 Views
Last post by theWIFES_S70
- 1577 Views
Last post by BlackBart
- 14 Replies
- 1544 Views
Last post by vtl
