Large Evap Leak 03 XC90 T6
caffeinejunky
- Year and Model: 2003 Volvo XC90 T6
- Has thanked: 1 time
I’m replacing an ignition coil and so I have everything off the engine for that. I also have a check engine light for a large evap leak. Anything I should check in relation to the evap leak while I have this stuff off? It’s preventing me from passing smog.
- RickHaleParker
- Been thanked: 979 times
Possible source
Major leak:
Major leak:
- 1. Fuel tank filler cap missing, not tightened or defective seal.
2. Leakage that is 1 mm or greater in the fuel tank, fuel filler pipe, fuel tank filler cap, EVAP canister, canister purge (CP) valve, or in the hoses between these components
3.The fuel gauge does not function (This fault is detected by the rear electrical module).
Active
Past
Past
- 548 Views
Last post by shiloh51933
- 2788 Views
- 969 Views
Last post by xHeart
- 15 Replies
- 7060 Views
- 3430 Views
Last post by SuperHerman
