IPD sale Volvo Parts
3.2l 2010 thermostat change
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Justtellme
Year and Model: 2010xc90 1991 780
Canada
Post by Justtellme » Mon Feb 04, 2019 4:21 pm
Ok..looking to swap my thermostat in a 2010 xc90 3.2.
Ive read
“On the short 6 engines to fill block you can slide the pinch clamp up on the short hose from rad to the trans cooler on left (driver’s) side and slip that hose off the cooler nipple. Use a section of heater hose or clear vinyl tubing that fits the nipple and put funnel into the hose. Add the premixed coolant/water and fill that. It will take about one gallon but you’ll add, water 30 sec and add again a few times.”
The above description of where to refill does not seem very clear to me.
ive pulled out the induction intake pipe and had a look at the left inner side of the radiator and see the two trans cooler lines going into the left hand side header of the radiator. Not seeing a separately described trans cooler or cooler nipple.
Can someone recommend a process to drain down the coolant level to the thermostat only, then retop up the coolant after swapping the thermostat?
Patrick
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 7 times
Been thanked: 7 times
United States of America
Re: 3.2l 2010 thermostat change
Post by pgill » Tue Feb 05, 2019 11:06 am
To answer your question, see the red arrow in the picture below
However that is not what I did for either of my 3.2's
To bleed the coolant I disconnected the block bleeder hose filled the reservoir until coolant escaped from the block bleeder hose and then reconnected the block bleeder hose.
Then I started the engine and let it get hot enough for the thermostat to open.
I did this with the cap installed.
The reservoir volume dropped.
Next I allowed the engine to cool.
Then I refilled the reservoir.
Good luck
Paul
PS Here is the list of high mileage maintenance items that I put together for the 3.2
http://www.freel2.com/forum/topic32504.html
Typical repairs for high mileage 3.2
A) Thermostat – replaced mine at 10 years (also replaced two coolant hoses)
And here is everything that I replaced at the same time that I replace my Thermostat
http://www.freel2.com/forum/topic32245.html
Note: Land Rover used the Volvo 3.2 in the LR2 so you can use the Land Rover parts if you prefer
(that is what I did for my 2010 S80 3.2)
Justtellme
Canada
Post by Justtellme » Tue Feb 05, 2019 11:51 am
Thanks for the info, sadly my left side rad header has the transmission cooler integrated internally to the rad and doesnt look like that. The only thing coming out of the left hand side header is the bottom rad hose and the two trans cooler lines.
Ill have a look again, but perhaps they changed the design?
pgill
Post by pgill » Tue Feb 05, 2019 12:25 pm
Since you don't have an external heat exchanger you can ignore the recommendation to bleed the coolant at that connection and instead follow the procedure that I followed (See above)
Note: the Thermostat is at a very low point in the system, I recommend that you drain the coolant, replace the thermostat and install new coolant. (i missed this question on my first response)
Please let us know (a post here on this thread is fine) if the Thermostat was broken when you remove it. Also I recommend that you change the coolant hose and O-ring for the engine oil heat exchanger while you are in there.
Picture of a broken Thermostat
http://www.freel2.com/forum/topic33004.html
Have fun
Paul
Justtellme
Canada
Post by Justtellme » Tue Feb 05, 2019 7:16 pm
Paul,
Anychance you have a screen capture pic of the VADIS block bleed hose you are referring to?
Is it the one to the left of thermostat?
Patrick
pgill
Post by pgill » Tue Feb 05, 2019 7:47 pm
Patrick,
The small hose above the center of the intake manifold is the breather hose for the engine. Any air bubbles will be pushed out this hose into the reservior.
When I filled the coolant (with the small hose shown below removed) I made sure that i kept filling until coolant came out of the location shown and when it did I reconnected the hose.
Hopefully this helps.
engine coolant bleed hose.jpg (67.94 KiB) Viewed 179 times
Note: there should be another small hose that connects to the reservoir to let out any trapped air from the radiator.
Good Luck
Paul
pgill
Post by pgill » Wed Feb 06, 2019 9:11 am
Patrick,
If you crawl under the Engine you might find the following
For my 2008 LR2 - I have the drain
For my 2010 S80 - no drain
I don't know if its just a change that was made from 2008 to 2010 or if this is a difference between Land Rover and Volvo.
The location is the back side of the engine (exhaust side)
inlet pipe drain.jpg (121.52 KiB) Viewed 161 times
If you do have it and you remove it remember to only tighten it with 5 Ft*Lbs or 7 Nm
Note: For my S80 I only removed the drain at the radiator to get the coolant out
Thanks
Paul
xHeart
Year and Model: 1997 854 NA
Been thanked: 17 times
Post by xHeart » Wed Feb 06, 2019 12:49 pm
Golden Retriever | 2014 VIDA DiCE | 2013A XC90 +130kmi/210kkm | 2001 V70XC 1st Owner +190kmi/ +305kkm | 1997 Volvo 850 NA (2.5L/5) Sedan 1st Owner +172kmi/ +277kkm
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
pgill
Post by pgill » Wed Feb 06, 2019 2:57 pm
June,
that link is a very good discussion.
Thanks for sharing it.
Paul
Justtellme
Canada
Post by Justtellme » Wed Feb 06, 2019 9:34 pm
Thanks all, coolant changed, thermostat changed, thhough I did not need to remove the intake manifold?
Maybe there is more clearance on the later 3.2 engines?
Did not see a petcock on the rad, pulled the lower rad and only got out about 6-6.5 L. I likely missed some in the lowest part of the block or in the heater matrix.
Looks nice and clean and went with a 50/50 mix
Again, thanks for all the hints on this one.
Patrick
Who is online
Users browsing this forum: No registered users and 13 guests
