IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Kallekula's 2001 Wagon Relapse Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
kallekula
Year and Model: S70 2000
Has thanked: 22 times
Been thanked: 26 times
Re: Kallekula's 2001 Wagon Relapse
Post by kallekula »
Bonus pic of old bent intake valves:
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Cleaned Pistons and block mating surface:
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Head bolted back on. Gasket is Fel-Pro, managed to screw up the Reinz when I tried to put the head on with turbo and manifold :x. Note my cool pink converter!
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Little bit of work Done over the weekend. Mounted exhaust manifold and turbo and hooked it all up. Old yucky turbo vacuum hoses replaced with silicones
BMW 540i 2002
S70 Base 2000
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 379 times
Been thanked: 1186 times
Re: Kallekula's 2001 Wagon Relapse  Topic is solved
Be careful with those valves if you start gnawing on them. Turbo valves are sodium filled - which can be a lot of fun to play with.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
kallekula
Post by kallekula »
Car done :). Started up without problem but ran rough. Swapped out one ignition coil that was bad.
BMW 540i 2002
S70 Base 2000
Looking good. Spent last week in the OC, should have looked you up and come messed up your ETM like I did with Evan.
kallekula
Post by kallekula »
abscate wrote: Sun May 05, 2019 9:06 pm Looking good. Spent last week in the OC, should have looked you up and come messed up your ETM like I did with Evan.
Next time
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Transmission flushed
BMW 540i 2002
S70 Base 2000
Hang another unit of Type 3309, Doctor.
+1000 points for the clever flush adapter
+ 6000 points for the zipties
