XC90 Key transponder failing.
I have seen that others have this issue as well. My car is 2012 xc90. It intermittently wouldnt start, but last night and this morning i am having no luck. The dealership is telling me its about $400 for a new key + tow. Has anyone else found a more reasonable solution?
- Been thanked: 504 times
Happened to my 2005 XC90 key.
Keep the FOB, if you replace ONLY the key portion, then about $250.
I posted some info in forum.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
As a point of clarification, engine turns over with the key but does not start or does not turn over at all? And you have only one key so cannot compare against another?
yes. i only have the one key.
no, the engine does not turn over. i get the error of start failed, try again.
someone in my IT departmment thinks the circuit may be damaged. they are gonna try and check it today and see.
hebhere
- Year and Model: 2005 xc90 tr6
- Has thanked: 1 time
- Been thanked: 2 times
Both of my Key Fobs need programmed. The key works, not the remote. I do have a Valet Key also, which is what I use. At the my friend's shop, where I help him at times, we can get every key re-programmed for about $100.00, some we are able to do ourselves. But, not the Volvo Key Fob......Nope, Volvo has that locked in. I was told by the dealer $350.00 per fob. What is bad is it only takes a few minutes to do.........Been living with it this way..... Will continue to do so unless I win the lottery.
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
We can unlock remotes. After this procedure you can program it to car, use official VIDA or we can program it use our own methods.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
By any chance does the key NOT stay latched 180 degrees from the folded stored position? If the key doesn't stay latched then the chip can be out of range when the remote folds over at 90 degrees to key.
- 30 Replies
- 25125 Views
Last post by BobbyS1
- 11 Replies
- 17916 Views
Last post by kcodyjr
- 5874 Views
Last post by 850forum
- 28 Replies
- 6283 Views
Last post by precopster
- 2004 Views
Last post by volvolugnut
