2004 XC90 rear tire smoking Topic is solved
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
I noticed a burnt smell coming from one of my rear tires, after driving it she got so hot there was smoke. When I took the tire off it was clear that the smell was coming from the brake pads. I replaced the Brake caliper and then I bled the break, there was a steady stream of fluid and no air. I put the tire back on took her for a test ride and the break sinks really low so I popped the tire off and tried to blead the brake again with the same result. I wouldn't have thought that I would need to bleed all four breaks by just removing one caliber? Do you think it could be the brake line to that caliper?
joejoethedogfaceboy
- Year and Model: 2012 XC60 3.2L
- Has thanked: 2 times
- Been thanked: 6 times
Is it still locking up? It could be the brake line, and worth the effort to replace on that aged car even if it doesn't fix it. My '04 XC90 (no longer have it) had a problem with one locking front caliper, and it turned out to be the valve body in the ABS module. Check out this thread for someone else with the same problem and some directions on how to troubleshoot. viewtopic.php?f=10&t=82594&p=448924#p448924
If the ABS is the issue, removing the ABS module is pretty straightforward, and you will need to disassemble your existing one to bring the control module over to the replacement ABS unit. (IIRC they are matched to the car?)
HTH -Joe
HTH -Joe
2012 XC60 3.2
2012 S60 T5
2004 XC90 2.5T (SOLD 11/2017)
1999 S70 GLT (24hrs of Lemons bound...)
2012 S60 T5
joejoethedogfaceboy
Might need to bleed the other brakes then.
2012 XC60 3.2
2012 S60 T5
2012 S60 T5
- SuperHerman
- Been thanked: 207 times
I think you will need to bleed all four brakes, starting with the furthest away and moving to the closest to the brake reservoir. It wouldn't hurt regardless to put new fluid in there. A brake bleeder will help keeping air out of the system. Also, check your brake fluid level.
As to whether the inside brake drums are the problem regarding the initial lock up, you can tell by rotating the tire while it is off the ground. You should not hear anything and it should rotate fairly easily.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
In addition to the flexible brake hose collapsing inside in which case they can sometimes act like a one-way check valve not allowing the caliper to release after you release the pedal...
Don't forget you have a parking brake mechanism buried underneath the rotor. You probably want to check that too if you think it's still trying to lock up. The friction material is known to delaminate from the steel shoe and cause issues. Also at this age the springs/retention hardware can rust through causing drag and noise.
The spongy pedal is most certainly air in the hydraulic system.
xyourobob
So I replaced the parking brake pads about 3 months ago because they were so deteriorated that they were floating around in there. I released the adjustment for these under the center console But I never readjusted them after putting on the new parking brake shoe pads. When the parking brake is engaged the pads don't even come in contact. It's on my list of things to do but I don't believe that's what's causing this problem. I'll bleed the brakes all around and report back. Thank you for everybody's feedback
xyourobob
Turns out I ordered and installed the wrong side caliper (bleed nipple facing down), I got the correct caliper and bled the brakes and she is back in action. Thanks again.
- 2269 Views
Last post by SuperHerman
- 1003 Views
Last post by Masscomguru
- 2076 Views
Last post by vtl
- 565 Views
Last post by Raul_duke
- 15 Replies
- 3315 Views
Last post by rspi
