400hp Volvo 850 platinum edition wagon
Kolbrick
Year and Model: 1996 Volvo 850 turbo
Has thanked: 2 times
Been thanked: 2 times
Post by Kolbrick »
I'm new to this forum and figured I'd share a build thread for those of you that are interested. I'm 20 years old and have been saving for a long time to build this car, I've went through 3 autotragics in the past year πŸ™„
The mods the car had prior to tearing it apart was IPD full catless exhaust, IPD turbo controller valve, rebuilt td04hl 16t angled flange turbo, DO88 front mount intercooler, Reverse intercooler piping, All snabb boost piping, IPD sway bars, Koni lowering springs, brand new polyurethane bushings all over the suspension, StopTech big brake kit 2 piece rotor 4 piston caliper brakes. The car itself Is a 1996 Volvo 850 turbo Platinum Edition wagon with approx. 190k miles.
The manual swap came together when I found a 1997 Volvo 850 5 speed for 500$. I now have the motor and transmission pulled out of that car, and have my wagon in the garage with the motor and autotragic pulled out. The block itself is at the machine shop right now, and my parts list goes as follows, please feel free to give me any suggestions or ask any questions, as this is alot to take on at one time.
Engine
β€’ NA Intake manifold 960 throttle plate
β€’ ARD R exhaust manifold
β€’ ARD Td04 22t billet turbo with 9 blade turbine
β€’ Snabb fresh air intake piping kit
β€’ Vast tuning
β€’ E85 compatible fuel pump with Bosch 650cc injectors
β€’ New intake/exhaust valves
β€’ 5 angle valve job/cylinder hoaning
β€’ Stiffer valve springs
β€’ Enem 35-78-000 camshafts
β€’ Glyco main bearings/rod bearings
β€’ K1 Forged connecting rods
β€’ Weisco forged pistons 81.25mm ( possibly 81.5mm waiting on machine shop )
β€’ ARP 2000 head bolts
β€’ CBV blockoff plate Tial blowoff valve
β€’ MSD coil
β€’ Looking at a MishiMoto catchcan
β€’ D088 aluminum radiator to go with the intercooler
Transmission
β€’ M56L 5 speed swap
β€’ Spec stage 3+ clutch and pressure plate (part number SO133F)
β€’ Gripper 40/65 Ramp Limited Slip Differential
β€’ Stick shift axles
I'm hoping to have this done by April/May and by June have the tune completed and shooting for the 350-400whp range. Feel free to give me some feedback/questions or tips on my build. :D
Stock internals
Stock internals
Stock valves
Stock valves
N/A engine manual transmission. Stock angled flange td04 16t turbo
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Awesome. Thanks for sharing, keep us updated, and welcome to MVS!
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Impressive list. I'm interested in how you came to choose the 22T turbo over the other options for this. What tires will you put on?
Also -> Amazon link
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
wow. amazing to have such a car at 20. beautiful. You will probably have more input over at sweedspeed for this sort of thing as this
forum is for grocery getters and diy on the cheap.
Kolbrick
Post by Kolbrick »
matthew1 wrote: 13 Feb 2019, 15:01 Impressive list. I'm interested in how you came to choose the 22T turbo over the other options for this. What tires will you put on?
Well as far as the Td04 family goes this is the biggest turbo at 50mm inducer, and with how much I'm already doing to the car i don't want to have to get a new downpipe fitted/fabricated and have to worry about clearance issues. One day i'll have the engine sleeved and run a big frame :D Continental DWS06 W speed rating (168+mph) is what is on it now, i'm hoping with the LSD i wont have too much problems with 20-40mph rolls. If i go to the strip i'm going to try it on street tires and maybe stepup to slicks. Spinning the tires is always safer for the axles though :mrgreen: Whats some common turbo options you see on these builds?
matthew1
Site Admin
Post by matthew1 »
All seasons? That's a lot of power, speed and cornering capability for those. Speed rating is fine, but all-around staying on the street is what I'd worry about.
I had DWS and they were fine for what they were.
Usually you see 19T or K24 etc., OEM turbos in other words.
Also -> Amazon link
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Get yourself a set of Pilot 4S, you won't regret it. I made the step up from good AS tires to Pilot Super Sports and it was a massive improvement.
What have you got going on for dampers?
Kolbrick
Post by Kolbrick »
j-dawg wrote: 14 Feb 2019, 15:04 Get yourself a set of Pilot 4S, you won't regret it. I made the step up from good AS tires to Pilot Super Sports and it was a massive improvement.
Koni FSD shocks/struts, they work great. I'll have to look into those pilots. I have a set of adjusting Koni sports, but they are way to harsh of a ride even on the softest setting. If I go to a track I would definitely run the Koni sports.
Has thanked: 1609 times
Been thanked: 4065 times
tardcart wrote: 13 Feb 2019, 15:39 wow. amazing to have such a car at 20. beautiful. You will probably have more input over at sweedspeed for this sort of thing as this
I've heard Swede-Speeders reuse engine oil, just saying....
Has thanked: 2199 times
Been thanked: 1852 times
There is a 850 for sale up here in Canada with a claimed 400 whp:
https://www.kijiji.ca/v-cars-trucks/edm ... nFlag=true
