Hey guys,
I have a 1996 Volvo 850 R and read today a fews code erros with a flash code reader and would like to ask members to help me out with the potential causes. Sorry, these might sound basic to you guys, but not a lot of info down here (Brazil) on these topics.
Truly appreciate the support.
Thanks
Mario
Port 3 (suppose Motor issues, right?)
121
Port 13: (suppose cruise control, right?)
122
Port 6 (Climate control, right?)
124
126
134
145
211
235
322
325
411
417
1996 Volvo 850 R - Help with error codes. Tks from Brazil
- RickHaleParker
- Been thanked: 977 times
You need to read up on this. Your information is not in the correct format ... A1 vs B1 ... ect.
Start here read the whole page. Next: at the top of the page is a link to 1996-1998 cars.
Active
Past
Past
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I think he's using the OBDII connector with a flash code reader, not the under-hood thingie or an "actual" OBDII device. So his format is correct.RickHaleParker wrote: 13 Feb 2019, 19:30 You need to read up on this. Your information is not in the correct format ... A1 vs B1 ... ect.
OP; the first thing you should do is clear all those codes, drive the car for a while and see what comes back. Intermittent situations can be read as errors, and the different CUs can set codes that aren't really relevant. If you clear them and they come back within a short amount of time, you can start tracing causes.
Your 121 code could be a MAF error - check and make sure it's plugged in when you've cleared the code, take a peek at the connector and see that it's not full of dirt or something. Unless you're running rich with black smoke and that "burned dust" smell to the exhaust, it could be a transient code. But clear them, drive, check again, post what comes back here, and we'll try to help.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
A load of rubbish, now removed to avoid confusion.Sommerfeldt wrote: 14 Feb 2019, 03:54 Your 121 code could be a MAF error - check and make sure it's plugged in when you've cleared the code, take a peek at the connector and see that it's not full of dirt or something. Unless you're running rich with black smoke and that "burned dust" smell to the exhaust, it could be a transient code. But clear them, drive, check again, post what comes back here, and we'll try to help.
- S
Sommerfeldt
No... I don't think that's correct. 5 would be the interrupted ground for initiating the reading and clearing the codes, wouldn't it?Cookeh wrote: 14 Feb 2019, 04:05 Is port 3 on the OBD-II device in the cabin not for ABS? I use Port 5 to give engine codes. This would make DTC121 an error with ABS sensor on left front wheel.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Cookeh
Quite right, getting mixed up with the interrupted ground. Carry on, ignore my lack of functioning braincells.Sommerfeldt wrote: 14 Feb 2019, 04:33No... I don't think that's correct. 5 would be the interrupted ground for initiating the reading and clearing the codes, wouldn't it?Cookeh wrote: 14 Feb 2019, 04:05 Is port 3 on the OBD-II device in the cabin not for ABS? I use Port 5 to give engine codes. This would make DTC121 an error with ABS sensor on left front wheel.
- S
marioguernelli
Hey guys appreciate the support. Yes, my model has a OBD2 reader at the center console under the radio and I read the codes with a home made flash reader based on the discussions I saw here at the forum.
Tne car is really running rich. I don't get black smoke however it smells non-burned gas. I tried cleaning the MAF with the electronic contact cleaner however, it did not work out. I am also getting lambda light on the dash. I have ordered a new MAF - will try it out once arrives.
Do you guys thing the Lambda could be o2s sensor?
tks again
Mario
tks again
Mario
Sommerfeldt
In my case, the MAF went first and then the O2 wasn't far behind. Could be either/or, but since you're getting a code for the MAF, that should be top of the list in any case. The O2 would set some long term fuel trim code or other, in most cases.
Remember that you can't use anything other than original Bosch MAF on these cars. For some reason, all the aftermarket units we've seen have failed to work properly.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
marioguernelli
Tks truly appreciate. I guess i will have to get an original bosch then ... no Chinese version. Tks
marioguernelli
I heard that the Renault Sefrane uses the same type - anybody heard it too? tsk
- 1394 Views
Last post by tryingbe
- 35 Replies
- 14151 Views
Last post by mrHook
- 791 Views
Last post by Ozark Lee
- 1944 Views
Last post by Addswing20
- 11 Replies
- 3705 Views
Last post by gcb50
