Are instrument clusters from pre '96 850 interchangeable with '96 & '97?
Junkyard close to me have '94 & '95 850.
Also...i read somewhere that s,v70 instrument clusters from '97 & '98 ONLY are direct fit to 850...are they?
I have a broken odometer gear for the last 10 or more years and i would like to fix it.
S,V70 clusters are more interesting to me because of digital odometer....but would they fit and work without modification?
Early & late 850 instrument cluster compatibility Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
You could just buy the odometer gear itself, very cheap and takes about an hour to fix. Lots of guides on here and other places covering the odometer gear replacement.
- misha
I know all of that...but just for the price of shipping(probably for less than that) i can get a used instrument cluster from junkyard or from private seller.
Eu market doesn't have those odometer gears for 850 and shipping from U.S costs more than the whole gear kit from ipd or fcp.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Cookeh
You can get them from Germany or the UK for around 11 euro, not sure what postage is. If you can get an instrument cluster for that or less then it would be a lot easier as you say. Instrument clusters in the UK are more like 60 euro typically though, so I presumed it was similar elsewhere.
- misha
Have a link?
Postage alone from U.S to Serbia is around 40$ plus 25$ for a gear kit...plus custom taxes.
I can get a cluster for 20-25€.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
There is a difference in the speed sensor setup between the early and late models. The early models with the speed sensor on the transaxle have a sine wave output. The later models have the square wave pulse train that is generated by the ABS wheel sensors and, after being routed through the ABS module, it feeds the cluster. Both systems use the same frequency / axle revolution.
Using a newer cluster in an older car is pretty easy, just tap a wheel sensor and you then have the square wave that the cluster wants to see. Using an older cluster on a newer car falls into the "I don't know" category since I don't know how the circuit actually works. If it is just counting pulses once they get over a voltage threshold then it really won't care what form the signal comes in as and an older cluster should work fine. If I were designing that circuit that circuit I would use a comparator with a mid point threshold on the sine wave to essentially convert that sine wave into a digital signal but I didn't design the circuit and I've never tried using an older cluster on a newer car.
- misha
You're talking about early and late 850 clusters...right?
I just read about this in some old thread here on MVS and on volvospeed.
It seems that i would need '96 or '97 850 cluster or s,v70...but from '97 & '98 ONLY.
'99 or '00 will not work.
What about odometer mechanism...can i just swap it out from older to a newer cluster?
I read on volvospeed that there are two types of gears....with more and less notches.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Cookeh
Here you go - not sure which of the two gears has died in yours, or which of the two cluster types you have - so this covers all three.misha wrote: 14 Feb 2019, 07:21 Have a link?
Another option for VDO-types is this link, which has both of the odometer gears but is more costly as a result.
Again, not sure what postage is so that might drive the cost up.
- misha
Thanks...it's VDO latest cluster(car is '97) for 850.
I'll see what my options are.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Look for PN, and then see models use it https://parts.volvocarslisle.com/Volvo_ ... ected.html
- 1448 Views
Last post by Knullruffs
- 4960 Views
Last post by oragex
- 4446 Views
Last post by polskamafia mjl
- 2015 Views
Last post by jrob0201
- 724 Views
Last post by camjohns
