Trying to find part number for the seat parts for my make and model. I need the passenger seat plastic trim piece on the outer side that holds the electric seat controls. Piece color is oak I think but beggars can't be choosers. I'm pretty sure it is #17 in the diagram in the link. The website shows the picture but no numbers since that part is no longer available I assume.
Thanks
https://www.myswedishparts.com/images/p ... 259023.jpg
09 S60 seat part numbers
- RickHaleParker
- Been thanked: 977 times
The part numbers are going to be determined by the part you need and the interior code. Each color has a different part number. You can find your interior code on the product ID plate. Your's should be located on the B-pillar facing the rear right hand side door. Open the right rear door and look for it.
1 – VIN Code
2 – Interior Code
3 – Exterior Paint Code
4 – Special Vehicle Number (Taxi, Police, etc.)
5 – Front Suspension Spring Code
6 – Front Suspension Strut Code
7 – Front Anti-Sway Bar Code
8 – Rear Suspension Spring Code
9 – Rear Suspension Shock Code
10 – Rear Anti-Sway Bar Code
11 – Front Suspension Bump Stop Code
12 – Rear Suspension Bump Stop Code
1 – VIN Code
2 – Interior Code
Active
Past
Past
- RickHaleParker
Do you still have the old one? There should be one or two Volvo part numbers on the back side of it.
IF two, one is the part number for the base (gray) and the other is for that color.
Got a Pick-n-Pull in your area? That part was used in the S60 01-09, V70 XC70 01-07, XC90 03-13 & S80 99-06.
Active
Past
Past
