I've a bit of a head-scratcher. I'll drive my 2005 xc90, it gets up to temp just fine & holds at half meter. when the engine cools down, the "low coolant" alert pops up. I check the tank, it's a little low. pop the cap, pressure release & the level comes back up to max & the alert goes away.
I've replaced the resivoir cap, the coolant is bright green & clean looking, the oil is normal & the exhaust doesn't smell like anything. No noticeable leaks.
I'm not really sure where to start with this one.
Help appreciated.
Coolant system issues Topic is solved
dantmcclellan
- Year and Model: 2005 XC90 2.5T AWD
dantmcclellan
I should also add, it's winter in mn, hasn't been above freezing for a month or so, heat blows hot.
dantmcclellan
Yep, tested positive for combustion gasses. I thought that was odd since there are no other signs of a bad head gasket. I guess I was in denial. Lol.
I think I'm going to try BlueDevil.
- 3116 Views
Last post by 1997volvo850
- 11 Replies
- 3414 Views
Last post by cn90
- 1044 Views
Last post by Rattnalle
- 11 Replies
- 355 Views
Last post by Grantkat
- 1333 Views
Last post by bkw1962
