IPD sale Volvo Parts
Did you know? 🤔
Oil Leak on Turbo charger oil drain/vent pipe at block
1996 - 2004 S40
1996 - 2004 V40
jumbicat
Year and Model: 2003 S40 2004 S60
Has thanked: 0
Been thanked: 0
United States of America
jumbicat
Post by jumbicat » Sat Feb 16, 2019 1:25 pm
The oil vent pipe on bottom of turbo charger had a leak at engine so replaced seal. Thought I may have cut it putting it in because the leak continued. Verified seal was cut. Bought another seal and noticed oil spitting out once oil pressure came up. I pulled the oil cap off while testing the 3rd seal and noticed with cap off, oil sprayed out of block. Am I looking at a head gasket issue? New turbo charger fixed the smoke issue but now I'm chasing an oil pressure issue.
RickHaleParker
Has thanked: 3 times
Been thanked: 296 times
RickHaleParker
Re: Oil Leak on Turbo charger oil drain/vent pipe at block
Post by RickHaleParker » Sat Feb 16, 2019 1:43 pm
Do you mean your getting pressure out of the oil fill cap, like below?
This is the test for a clogged PCV system (Positive Crankcase Ventilation) which is known to blow oil past seals.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
jumbicat
Has thanked: 0
Been thanked: 0
jumbicat
Post by jumbicat » Sat Feb 16, 2019 2:40 pm
No, I did this test before replacing turbo charger and the glove would inflate/deflate at a very fast rate. No positive pressure like the video. Odd that taking the oil cap off would cause oil to stream out the oil vent pipe seal at engine block. Put the cap on and it's a slow leak.
