IPD sale Volvo Parts
Did you know? 🤔
just picked up 2010 R Design need help
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
MrBreeze
Year and Model: 2007 Volvo S80 FWD
Has thanked: 0
Been thanked: 0
United States of America
MrBreeze
Post by MrBreeze » Sat Feb 16, 2019 9:13 pm
Just picked up a 2010 XC90 R-Design with 132K miles.
Two issues I need to address, The radio display is blank - turn on power and the Performance Sound logo comes on then nothing, no sound or display. Am able to access audio menu for treble/bass etc and the scale displays and responds to adjustments.
Second issue, when accelerating aggressively, there is a shudder in what I think is 3rd gear. goes away as soon as it up shifts to 4th. You can baby the pedal and smooth shifting is accomplished without the shudder. Does not happen every time, but every time you are aggressive on the gas.
Thoughts?
SuperHerman
Has thanked: 0
Been thanked: 94 times
SuperHerman
Re: just picked up 2010 R Design need help
Post by SuperHerman » Sat Feb 16, 2019 10:44 pm
As to your second question see here OP's second post for his symptoms: https://www.matthewsvolvosite.com/forum ... 10&t=88484
Your transmission does not have a dipstick, but a transmission drain and fill would be where I would start. If you have access to a scanner that reads what the transmission is doing that would also help - maybe you have a failing solenoid.
poconosms1
Year and Model: 2010 XC90
Has thanked: 0
Been thanked: 0
poconosms1
Post by poconosms1 » Sun Feb 17, 2019 5:33 am
agreed. dropping the pan will reveal a lot. I generally do NOT recommend a flush, just a drain a refill.
Masscomguru
Year and Model: 2008 XC90
Has thanked: 0
Been thanked: 3 times
Masscomguru
Post by Masscomguru » Sun Feb 17, 2019 7:11 am
A common issue for shudder under heavy acceleration is the passenger side axle. It is very noticeable if you accelerate while changing lanes.
MrBreeze
Has thanked: 0
Been thanked: 0
MrBreeze
Post by MrBreeze » Sun Feb 17, 2019 8:27 pm
Found this for the infotainment blank screen maybe?
https://xemodex.com/us/product/infotain ... 236-10-20/
$349.00 shipped both ways.
Will do some more research on this.
MrBreeze
Has thanked: 0
Been thanked: 0
MrBreeze
Post by MrBreeze » Sun Feb 17, 2019 8:36 pm
in regards to the XC90 front right axle, does the same part fit R-Design and non R models?
anyone use after market parts? https://www.rockauto.com/en/moreinfo.ph ... 31&jsn=434
Masscomguru
Has thanked: 0
Masscomguru
Post by Masscomguru » Mon Feb 18, 2019 4:17 am
There have been lifespan issues with aftermarket axles. You could probably do better finding a used one from a newer xc90 with less mileage.
SuperHerman
Has thanked: 0
SuperHerman
Post by SuperHerman » Tue Feb 19, 2019 12:04 am
See this: https://www.ipdusa.com/techtips/10176/v ... ion-issues
and this TransGo kit: http://www.transgo.com/products.php?cat ... uct_id=269
Assuming it is not your axle. Another forum member is having similar issues.
MrBreeze
Has thanked: 0
Been thanked: 0
MrBreeze
Post by MrBreeze » Tue Feb 19, 2019 4:30 am
I will be removing the radio from dash and checking if there is fiber optic light coming from the unit, starting there, then will bypass other units if it is working. The Nav unit isn't working either.
Have driven about 200 miles since my original post, the shudder only happens about 10-20% of the time, lots of opinions out there from solenoid to right axle to torque converter, maybe 3rd gear band, or fluid flush. My Volvo mechanic says the dealership just replaces transmissions and rarely takes them apart?? WTH
MrBreeze
Has thanked: 0
Been thanked: 0
MrBreeze
Post by MrBreeze » Tue Feb 26, 2019 6:10 am
Removed radio head from dash and had light in the fiber optic, light in the amp, but no light in the Nav unit under front seat, so figured a break between amp -Sat -Nav, initially I had checked the radio 10 amp fuse, and it was fine, decided to go back and check the 30 amp Amplifier fuse, lo and behold it was burnt. Replaced fuse and everything works now including the Nav unit.
Moral of that story, check ALL appropriate fuses in the chain. Sigh
