window controls
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
1998 V70 T5 wagon. I was lubricating the window guides. All windows worked from the driver's master control. Started using the rear passenger window control. Window went down/up/down/up/down and now won't move. Stuck wide open. Interior lights dim slightly when the rear passenger window control is activated but window doesn't respond at all. Nothing changed that I know of. This window also does not work using the driver master control. All other windows work from master control. Before I start replacing the rear passenger control, is this the likely problem? Seems odd that it would stop responding to both the rear passenger door control and the main control at the same time. Or is there some other more likely problem. Thanks.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- yair
- Year and Model: 1997 940 sw
- Has thanked: 1 time
- Been thanked: 3 times
If lights dim when you press the button, it means that there is some current drew, so it looks like the switch is working. Maybe check for a mechanical problem, something that blocks the window movement, or the motor itself.
yair
1997 940 wagon
2005 XC90
1996 855 Turbo
1995 850 n/a, rest in pieces.
1997 940 wagon
2005 XC90
1996 855 Turbo
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
i had an overlubricates window on a Ford once. thick grease can actually add quite some friction in cold weather.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
enotslim
The window works after a good night's sleep. Good thing. I have an hour of highway driving today and it's 15˚F right now. No need for window cardboard and snow pants inside. But why did this happen and will it recur? The car was outside at ~25˚F when I brought it into the garage. The window stopped working about 10 minutes later after lubricating the guides with lithium grease. I know silicone might be better (at least it's not white) but I didn't have any. And I don't think lithium grease should seize up at these temperatures. It's recommended for the window sliders (which, ironically I had just replaced on my 2004 XC70 not 30 minutes before the V70's window froze - no good deed goes unpunished). The V70 was in the garage ~45˚F overnight. Now it works. I'm hesitant to use that window. I don't have much use for it given that the rear passenger seat is rarely occupied.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
I use silicone spray to lube. You probably just tripped the circuit breaker under the hood ( small metal boxes in the main fuse box ) which reset themselves after they cool off In 30 minutes or so
- 1501 Views
Last post by RickHaleParker
- 512 Views
Last post by precopster
- 2619 Views
Last post by kosh_al
- 705 Views
Last post by oragex
- 838 Views
Last post by Tiny Tim 077
