IPD sale Volvo Parts
2011 XC90 - My car eats batteries for lunch...
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
JohnCC
Year and Model: 2011 XC90
United States of America
Re: 2011 XC90 - My car eats batteries for lunch...
Post by JohnCC » Sat Feb 23, 2019 9:48 am
I have been doing something similar, when I remember. The battery is always showing a good charge state when I shut it down, 12.6 volts or so, and generally shows about 12.3 the next morning. 12.3 indicates significantly under charged, and even if it is not accurate, a drop of 0.3 volts seems significant. I did pull that fuse once, and don't remember the numbers, but I recall I decided it did not fix the problem.
The problem is, I'm so programmed to jump in and start the car that getting consistent, frequent readings is a problem.
John C
2011 XC90 3.2
166,000 miles and counting
1965 122S B18D gone but not forgotten
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 147 times
Been thanked: 444 times
Trinidad & Tobago
Post by abscate » Sun Feb 24, 2019 6:20 am
Measure the battery voltage after shutdown and 30 seconds of headlights on
You need to deplete the surface charge from the battery before measuring resting voltage
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
RickHaleParker
Has thanked: 2 times
Been thanked: 228 times
Post by RickHaleParker » Sun Feb 24, 2019 7:14 am
Use to pick up late 90s Lincoln Continentals dirt cheap because they ate through batteries and alternators. Would take them and redo the grounding straps to the firewall, problem solved.
You might want to check all your main grounds ....
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
JohnCC
Post by JohnCC » Sun Feb 24, 2019 8:17 am
I turn the key to position 1 and wait about 30 seconds, until the reading stabilizes. After a long trip it usually settles down around 12.6 and after a short trip more like 12.4.
John C
2011 XC90 3.2
oragex
Year and Model: S60 2003
Has thanked: 76 times
Been thanked: 134 times
Canada
Post by oragex » Sun Feb 24, 2019 9:43 am
0.3v over night means about 30-40% discharge, clearly a parasitic drain somewhere
I'd recommend this in the first place, to disconnect it each night, it will save you the battery for now. Remember to have the key in POS II when reconnecting and make sure trunk and door locks work manually. Charging -discharging a car battery is what is killing them, unlike a phone battery, lead acid ones hate being discharged.
www.youtube.com/watch?v=lMT1RdnkxnY
www.youtube.com/watch?v=jdW0t2FJCfA
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
JohnCC
Post by JohnCC » Sun Feb 24, 2019 12:58 pm
Ay, there's the rub. No way to get in the (locked) tailgate without the battery and no (easy) way to connect the battery without opening the tailgate...
John C
2011 XC90 3.2
Trinidad & Tobago
Post by abscate » Mon Feb 25, 2019 4:56 am
That is such a PITA isn’t it? Happens on my P2 and the E83 Bimmer
You can run a pigtail out of the trunk and hook up a jump battery to open the trunk , BTDT
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Who is online
Users browsing this forum: Sannerdm, wanderdüne and 19 guests
