IPD sale Volvo Parts
Did you know? 🤔
No spark after distributor
Rubenrodri126
Year and Model: 1997 850 t5
Has thanked: 4 times
Been thanked: 0
Mexico
Rubenrodri126
Post by Rubenrodri126 » Wed Feb 20, 2019 2:40 pm
Ok i replaced the head gasket on my volvo 850 1997 i put all together but for some reason i dont have spark after the distribuitor i mean i took the cable of the coil of and i have spark but nothing at the spark plugs i have fuel compresion and its on timing before i took the car apart it was running perfect any suggestions??? Please help
850 LPT
Year and Model: 97' 850
Has thanked: 19 times
Been thanked: 24 times
United States of America
850 LPT
Re: No spark after distributor
Post by 850 LPT » Wed Feb 20, 2019 3:05 pm
Are you using new parts for the ignition such as cap, rotor, cables and plugs?
The reason I am asking is that if you don't there may be something wrong with the old cap, since you you have spark going to it but not from it. So the cap would be my first suspicion.
I hope you get it running soon,
Dirk
96' 850 sedan, base, auto, pewter/charcoal, 106k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 209k miles
04' V70, auto, ash gold/ tan, 222k miles
05' V70, 5-speed manual, loaded, mistral green/ tan, 142k miles
79' Ford Capri S, Euro Spec 2.8 V6, T9 5-speed manual
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Year and Model: Many Volvos
Been thanked: 34 times
Post by Ozark Lee » Wed Feb 20, 2019 3:31 pm
If you are sure that you don't have spark at the plugs but do have spark at the coil it pretty much has to be the distributor cap and/or the rotor.
If you removed the wires from the distributor make real sure that they are reinstalled in the proper order. Both Haynes and the factory service manual have them labeled incorrectly.
The correct order is here:
https://www.matthewsvolvosite.com/volvo ... order.html
'99 V70XC - Nautic Blue
Rubenrodri126
Been thanked: 0
Mexico
Rubenrodri126
Post by Rubenrodri126 » Wed Feb 20, 2019 3:32 pm
Yes cap rotor wires and plugs i gap all the spark plugs to 25 wires are the same cap and rotors i took all apart again and inspect them all look perfect no cracks or nothing no crack wires
Rubenrodri126
Been thanked: 0
Mexico
Rubenrodri126
Post by Rubenrodri126 » Wed Feb 20, 2019 3:35 pm
When I took everything apart I number the cap and the wires in order so I don't get it mixed I put them on the order that I had I check the photo that you post and both are the same rotor it's in good condition and also in good condition I bought it like 2 months ago
Has thanked: 46 times
Been thanked: 139 times
Post by erikv11 » Wed Feb 20, 2019 5:37 pm
Check the circular, black metal brackets on the back end of the cams, there is one under the cap and there is a different one under the cam sensor. It is possible to put them on wrong and then you can get no spark.
It's also possible for the electronics inside the rotor to go bad, then you get no spark through the rotor. But sounds more likely related to the engine work, check those brackets.
'96 855 NA, 140k
'98 S70 NA, 205k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 275k
'06 S60 R, 155k
Rubenrodri126
Been thanked: 0
Mexico
Rubenrodri126
Post by Rubenrodri126 » Wed Feb 20, 2019 5:42 pm
Okay I'll try to check that apt I got the car to run a few seconds dad died and now I don't have any spark even at the coil or nowhere
Post by erikv11 » Wed Feb 20, 2019 8:28 pm
No spark from the coil is one possible result of a bad cam sensor. Could be the plate, could be something else. Worth also checking the cam and crank sensor connections.
'96 855 NA, 140k
'06 S60 R, 155k
Rubenrodri126
Been thanked: 0
Mexico
Rubenrodri126
Post by Rubenrodri126 » Thu Feb 21, 2019 2:59 pm
Ok so i check the little plate that goes at the cam shaft and one of the tapbs at the back its bend so it fits any way at the cam but also i saw that the camshaft sensor locks licke its mising something but i am not sure if its that way
jimmy57
Has thanked: 1 time
Been thanked: 125 times
jimmy57
Post by jimmy57 » Thu Feb 21, 2019 7:46 pm
The sensor wheel you are holding has been put on wrong. There should be two tabs sticking up. The tab to the right has been flattened by it being on top of the cam end instead of down in the slot ground on cam end. You might be able to pry that tab up and fit it correctly.
