IPD sale Volvo Parts
Did you know? 🤔
04 xc70 steering jerks on acceleration
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
mitchbyman
Year and Model: 2004 xc70
Has thanked: 0
Been thanked: 0
United States of America
mitchbyman
Post by mitchbyman » Wed Feb 20, 2019 7:38 pm
I have a problem with my 04 xc70, 115k miles. had issues with car tracking back and forth on the highway. also, loud clunking over bumps and road cracks. replaced upper strut mounts, bushings and lower control arms in the front. these noises went away. I brought it to shop to check alignment. they adjusted toe slightly. ... now, the car will pull hard to the left on acceleration, and swap back to right when I let off. unsure if toe is the issue, it's fairly unsafe to drive... anyone seen this and found a fix?
RickHaleParker
Has thanked: 3 times
Been thanked: 258 times
RickHaleParker
Re: 04 xc70 steering jerks on acceleration
Post by RickHaleParker » Wed Feb 20, 2019 7:45 pm
Take it back to the shop and give them the facts. See what they have to say.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
oragex
Year and Model: S60 2003
Has thanked: 76 times
Been thanked: 139 times
Canada
oragex
Post by oragex » Wed Feb 20, 2019 10:33 pm
You don't mention the brands used for parts? Something is loose to say the least. Not sure how the geometry would cause what you say, to me it's a suspension/steering part that's either not fixed properly or broken.
I'd try perhaps another shop..
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
mitchbyman
Has thanked: 0
Been thanked: 0
mitchbyman
Post by mitchbyman » Thu Feb 21, 2019 7:29 am
anyone know if subframe bushings could be bad? when I replaced the lower control arms, the old bushings in them were pretty bad.. wondering if the movement is no longer being compensated in the bad bushings and is now felt in the steering...
mitchbyman
Has thanked: 0
Been thanked: 0
mitchbyman
Post by mitchbyman » Thu Feb 21, 2019 7:30 am
also, I used parts from ipd, unsure the brand...
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 16 times
chrism
Post by chrism » Thu Feb 21, 2019 8:13 am
You symptoms are indicative of worn out or loose control arm bushings. If that's the case, it will pull in the opposite direction of the bad side when you accelerate. In your case - pulls to the left - check RH control arm.
Also make sure the LH axle is properly engaged with the differential.
mitchbyman
Has thanked: 0
Been thanked: 0
mitchbyman
Post by mitchbyman » Thu Feb 21, 2019 8:46 am
these are all brand new from IDP. front lower arms and bushings. just had the car in the air and used a prybar, couldn't find anything loose or sloppy in the front end.. or rear..
xHeart
Year and Model: 1997 854 NA
Has thanked: 7 times
Been thanked: 17 times
xHeart
Post by xHeart » Thu Feb 21, 2019 8:58 am
Various engine/ transmission mounts and pads are aging too. How is rear suspension?
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +140mi/225km | 2001 V70XC 1st Owner +190mi/ +305km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
mitchbyman
Has thanked: 0
Been thanked: 0
mitchbyman
Post by mitchbyman » Thu Feb 21, 2019 3:03 pm
I should have included, the car dives to the left while braking. really wondering what is going on, like the subframe the engine attaches to is slightly disconnected to the rest of the car?..???? im pretty new to Volvos, but seems like this car needs constant attention...
firstv70volvo
Year and Model: V70 T5 2001
firstv70volvo
Post by firstv70volvo » Thu Feb 21, 2019 4:41 pm
What's going on is your wheel alignment is changing under the stress of acceleration or braking due to worn ball joints or worn inner/outer tie rod ends or bad bushings or bad parts or bad assembly. Did these problems exist before you replaced the parts you mentioned previously? Since you've changed the lower control arms and assuming this was done correctly I think you should check the ball joints and tie rod ends. I suspect you may have badly worn ball joints, these cars are hard on them. Since the alignment shop didn't find what's causing the unwanted movement in the suspension/steering I'd take it to a different shop or check things yourself. With the symptoms you're describing the problem should be obvious, there's a lot of movement in one or both of your wheels.
