So my 2005 S60 was making some awful screeching sounds from the driver's side rear wheel. The parking brake components had come apart within the drum. I asked the repair shop (Firestone) to fix JUST THE PARKING BRAKE COMPONENTS and put it back together. I had wanted to do all of the brake pads/rotors myself on all 4 wheels. So the shop tells me if they open up the drum, they are required to replace everything on that wheel and everything on the opposite side wheel. Ended up paying $700 for all new brake components at both rear wheels.
Litigious society, snowflakes, hiding behind "policy", get off my lawn.
What else am I missing?
Sure miss the days of being able to have the repair shop do what you ask them to do.
recent brake job
- Been thanked: 504 times
Yes and No...in theory they could have replaced ONLY the drum parts (brake shoes etc.), but the rotors INNER surface is usually bad.
If REAR pads are OK, you can re-use them.
This is why I overhaul REAR brake (shoes, rotors, pads etc.) every 100K b/c the shoe backing material usually falls off by then, making a lot of noise.
I posted the DIY in forum (REAR brake overhaul for either 2004 V70 or 2005 XC90 etc.).
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
As cn90 mentions, the parking brake shoes push against a surface of the rotor for the rears. If that surface is damaged and cannot be machined then it makes sense to replace the rotors. And then if the pads are in a poor condition, you would not want to damage the new rotors with bad pads so those get changed too.
I think you got an offer from Firestone, that they would do everything on the rears. it is up to you to accept that or try another mechanic who might be more reasonable.
I had a stuck rear caliper and had my mechanic fix it and one new caliper, 2 rotors and pads ended up being about $600 (or so). As I had priced it, I was a little shocked at the extra on the parts and the labor cost. I soon after did tackle the parking brakes. I put on new shoes, springs, the 'h'-separator, but failed to get the expander released from the parking brake cable so I just reused it. This restored the parking brake so I could pass inspection.
I then did the front brakes with new rotors and pads and was pleased with the outcome. The fronts cost about $200, but I also spent about $100 in tools and various chemicals (lubes, cleaners, new torque wrench, etc).
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
If nothing else they should have told you at the get-go, BEFORE they tore it apart, "Mr. hu5ker, we would be more than happy to look into your brake problem, however I must let you know that if we take it apart we have to replace everything inside, on both sides, for a total of $XXX.xx. NOT wait and tell you after it's all apart.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The parking brake surface really isn't very important since its only ever used when stationary (if you want to stay alive). Uneven brake feel isn't a thing there.
I'd replace just the brake shoes if everything else was ok. Though if I was planning to do it all later I'd do it all right there so I didn't have to take it apart again.
Four hours labor with quality parts would come in at about $700
Just the front brake pads on the E83 Bavarian Money Waster were $90
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It is expensive but that's what garages do.. take our money. Brake jobs is what they like the most - and perhaps make the most quick profits. Worth searching a little on local.google.com for other garages around and read if they have any reviews.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
Sounds like they're full of it to me. I would never do business with that shop again.hu5ker555 wrote: 21 Feb 2019, 06:51 Sure miss the days of being able to have the repair shop do what you ask them to do.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 1768 Views
- 5258 Views
Last post by jimmy57
- 8889 Views
Last post by cn90
- 1908 Views
Last post by graysonboycie
- 581 Views
Last post by 1998v70xcbill
