IPD sale Volvo Parts
Did you know? 🤔
computer
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
G1022
Year and Model: 2005 s 60
Has thanked: 0
Been thanked: 0
G1022
computer
Post by G1022 » Thu Feb 21, 2019 10:13 am
does anyone know how to reset the computer on a 2013 XC 90
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 44 times
United States of America
ggleavitt
Re: computer
Post by ggleavitt » Fri Feb 22, 2019 10:36 am
ECM has software and learned adaptations, you can reset adaptations via VIDA/DICE (Diagnostics/Vehicle Communication/ECM/Advanced). Think you might also be able to reset the ECM adaptation values by disconnecting the battery negative lead and letting the car sit for a while (1/2 hour, maybe longer?), someone will need to confirm this. If you do remove and reconnect power, there's a best practices procedure to follow so as to avoid the possibility of module data corruption, SRS module coding or an unplanned air bag deployment.
As far as a software reset, I think this ends up being an ECM reload and to do a software reload you need the car connected to VIDA/DICE, logged in and connected to Volvo.
I might be way off but this is what I believe is the case. Not sure if that helps to answer your question.
2005 2.5T AWD-194k
2008 V8 AWD Sport-124k
jimmy57
Has thanked: 2 times
Been thanked: 149 times
jimmy57
Re: computer
Post by jimmy57 » Fri Feb 22, 2019 1:46 pm
Wat is the problem you are trying to do reset for?
G1022
Has thanked: 0
Been thanked: 0
G1022
Re: computer
Post by G1022 » Fri Feb 22, 2019 5:05 pm
OBD will not register failed inspection
