P80 PS pump orings 969092 dimensions request?
Has thanked: 1609 times
Been thanked: 4063 times
Anyone measured the dimensions so they can be bought locally without having to take the pump apart?
$2 from Volvo parts Lisle
0.29 for PPS from FCP with lifetime warranty to be round and green
:mrgreen:
High pressure pump line uses four of these, two at each end
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Active
Past
Awesome, thank you rick
measure the id to 0.307 a 302 pin is loose and a 5/16 pin is just a tad over. The width is 0.072 so the size they gave me is a -011. (5/16 ID by 7/16 OD 1/16 Wide) That size is included in the Harbor Freight HNBR set #67644 as reference if someone else gets stranded on a weekend. Be careful with using Home Depot o-rings. EPDM is very common for water etc and that will not do well with oil or gasoline.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I may have a spare at home in that pump I picked up. Want me to grab it? It will at least get you running for now...
Can you run it over to OH for me too?
πŸ˜€
wizechatmgr
As you're aware, forgot that sucker today. Would having it Tuesday be okay? I can bring the entire pump...
