You know the scenario - you are working on the car, then suddenly and O-ring is broken
Our great vendors have these parts, but you need to be back on the road now, and $20 shipping on a 0.29 cent part seems rough.
Goal - as we do our DIY jobs, document the size of Orings so we can find the right one locally and get out of a jam.
When you buy O-rings, buy 2 extra. You’ll figure out why
Format
Year Model Volvo part number Size OD by thickness, material, colour, comment
Onionrings
P80 Master O-ring Model Part Number Size Type Comment Thread
Space reserved for AC Orings
The comprehensive list of O rings on the AC system, 1999
Using Volvo Parts Lisle as guide
http://volvopartslisle.com/assembly/790 ... nditioning
Oring - evaporator cold side 3545416 2 on this line (4 total in system)
Oring Evaporator warm side 988840 2 on line this line (3 total in system)
Oring on pressostat valve (low pressure) 3537501 Qty 1
Orfice valve - downstream Oring 3537797 Qty 1 - this one comes with a new orifice valve
Orfice Valve upstream 988840 one on valve, comes with new valve (total 3 in system)
Oring for fill valve NLA? Fill valve is 6849305 - maybe comes with Oring
Oring between condensor and hard lines 9883337 qty 3 total in system
Condensor pipe to condensor hard line - NLA
Condensor to condensor pipe/compressor NLA
Oring from condenser pipe to compressor 6847526
Oring to compressor suction pipe 354441
ORing from suction pipe to drier 9888433
Oring from drier to hard line/evap warm side 3545416 2 at this location, 4 in system
precopster
- Year and Model: Lots
- Been thanked: 128 times
Great work I needed this when I was doing up my 850 wagon afew years ago.
Should A/C be somewhere in the title?
This is for all O-rings, not just AC !!
Ill work on measuring the AC ones since I have spares.
precopster
O ring for vacuum tree on manifold turbo cars?
While you're at it.
While you're at it.
Some o-ring additions
Measured on an 1999 Intake Cam
Outer Cap Oring 28mm x 1.5mm
Inner VVT hub Oring 50mm x 1.5mm
See screen shots for part numbers - it looks like I was measuring a part 9440651
On edit...I think these are the cam seals , not the CVVT Orings
- Screen Shot 2019-05-02 at 5.15.01 PM.png (248.13 KiB) Viewed 4029 times
- Screen Shot 2019-05-02 at 5.16.16 PM.png (71.57 KiB) Viewed 4030 times
Really good tutorial about AC refurb , setting up clutch. JimBee shared the things that went wrong , not just the list of stepsJimBee wrote: 22 Mar 2020, 19:34 On page 8 of this tutorial there are more spec's on o-rings for the p80 A/C system.
https://images.matthewsvolvosite.com/vo ... torial.pdf
- 1428 Views
Last post by tehniemer
- 708 Views
- 630 Views
Last post by wizechatmgr
- 172 Views
- 1943 Views
