IPD sale Volvo Parts
Did you know? 🤔
P80 Master O-ring Model Part Number Size Type Comment Thread
Has thanked: 165 times
Been thanked: 483 times
Trinidad & Tobago
Post by abscate » Fri Feb 22, 2019 2:08 pm
You know the scenario - you are working on the car, then suddenly and O-ring is broken
Our great vendors have these parts, but you need to be back on the road now, and $20 shipping on a 0.29 cent part seems rough.
Goal - as we do our DIY jobs, document the size of Orings so we can find the right one locally and get out of a jam.
When you buy O-rings, buy 2 extra. You’ll figure out why
Format
Year Model Volvo part number Size OD by thickness, material, colour, comment
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Trinidad & Tobago
Re: P80 Master O-ring Model Part Number Size Type Comment Thread
Post by abscate » Fri Feb 22, 2019 2:10 pm
Space reserved for AC Orings
The comprehensive list of O rings on the AC system, 1999
Using Volvo Parts Lisle as guide
http://volvopartslisle.com/assembly/790 ... nditioning
Oring - evaporator cold side 3545416 2 on this line (4 total in system)
Oring Evaporator warm side 988840 2 on line this line (3 total in system)
Oring on pressostat valve (low pressure) 3537501 Qty 1
Orfice valve - downstream Oring 3537797 Qty 1 - this one comes with a new orifice valve
Orfice Valve upstream 988840 one on valve, comes with new valve (total 3 in system)
Oring for fill valve NLA? Fill valve is 6849305 - maybe comes with Oring
Oring between condensor and hard lines 9883337 qty 3 total in system
Condensor pipe to condensor hard line - NLA
Condensor to condensor pipe/compressor NLA
Oring from condenser pipe to compressor 6847526
Oring to compressor suction pipe 354441
ORing from suction pipe to drier 9888433
Oring from drier to hard line/evap warm side 3545416 2 at this location, 4 in system
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Year and Model: Lots
Has thanked: 3 times
Been thanked: 87 times
Australia
Post by precopster » Fri Feb 22, 2019 2:46 pm
Great work I needed this when I was doing up my 850 wagon afew years ago.
Should A/C be somewhere in the title?
Current cars:2002 XC70, 2001 V70 T5, 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Trinidad & Tobago
Post by abscate » Fri Feb 22, 2019 3:09 pm
This is for all O-rings, not just AC !!
Ill work on measuring the AC ones since I have spares.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Australia
Post by precopster » Fri Feb 22, 2019 3:12 pm
O ring for vacuum tree on manifold turbo cars?
While you're at it. :D
Trinidad & Tobago
Post by abscate » Fri Feb 22, 2019 7:24 pm
Size for ps pump and rack hoses is here, each connector uses 2 on each end
https://www.matthewsvolvosite.com/forum ... hp?t=60914
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Trinidad & Tobago
Post by abscate » Sat Mar 23, 2019 4:00 pm
Some o-ring additions
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
