IPD sale Volvo Parts
Did you know? 🤔
V70 Pulling me off the road - like driving through a wind storm
2001 - 2007 XC-70
mminniefield
Year and Model: 2001 V70
Has thanked: 0
Been thanked: 0
United States of America
mminniefield
Post by mminniefield » Fri Feb 22, 2019 2:37 pm
Firstly, long time reader - first time poster.
I am struggling with a scary suspension problem with my 01 V70. The car pulls to the left under acceleration and to the right under deceleration. This problem is made worse with speed. It is almost impossible to keep it on the road over 45-50 mph. It darts around with the slightest change in speed. I have new tires, alignment has been checked by two different shops, recently replaced lower control arms and bushings. I had a bent rear track bar (foolishly used it as tow point to get unstuck from snow) but that has been replaced and rear full alignment completed afterward. I have had all 4 tires off the ground to check for slop in the steering and for loose and warn bushings. Everything seems tight. Where can I look next? Has anyone had a similar problem? I am at a loss and feel completely defeated. Seems like it should be obvious what is causing the problems. I will have to retire the 'ol girl if I cant find a solution!
June
Year and Model: 2004 S80 T6
Has thanked: 200 times
Been thanked: 97 times
June
Re: V70 Pulling me off the road - like driving through a wind storm
Post by June » Fri Feb 22, 2019 2:43 pm
Subframe bushings. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Has thanked: 191 times
Been thanked: 603 times
Trinidad & Tobago
Post by abscate » Fri Feb 22, 2019 3:06 pm
If they used Lower control arms of low quality, they can be bad out of box.
Recent thread in the XC90 with video - terrifying
mminniefield
Has thanked: 0
Been thanked: 0
mminniefield
Post by mminniefield » Fri Feb 22, 2019 3:14 pm
I actually pulled good OEM control arms off of a donor car. ( I have read its better to go with used OEM over cheap new/reman) The noted problem developed more than 6 months after control arm replacement. and both sides seem to be in good shape.
Has thanked: 54 times
Been thanked: 179 times
Post by erikv11 » Sat Feb 23, 2019 12:57 pm
Sounds exactly like bad front control arm ball joints.
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
Scottybee
Year and Model: 2002 v70
Has thanked: 0
Been thanked: 0
Scottybee
Post by Scottybee » Thu Jun 06, 2019 2:32 am
This you ever did this issue my v70 2002 same thing scares the poop outta me
veektor
Year and Model: 2008 S60
Has thanked: 3 times
Been thanked: 4 times
veektor
Post by veektor » Tue Jun 11, 2019 8:38 am
The control arms, especially the steel ones, are quite durable on their own, but the rubber bushings and the ball joints disintegrate over time. Those rubber bits are rarely worth reusing from salvage vehicles, unless you have definitive evidence those parts were new and installed on the donor very recently.
My S60 had 200K miles, and those bushings looked very bad. After considering the individual bushing replacement, the cost and time involved in doing that, I chose to buy new Lemfoerder control arms, which include new bushings, and also replaced the ball joints. It was a physically demanding job, I would hate to have to revisit it any time soon.
If the rubber bushings are as good as you say, could it be the bearings?
- Pete -
Year and Model: 01, 04, 04, 06 V70's
Has thanked: 14 times
Been thanked: 13 times
- Pete -
Post by - Pete - » Wed Jun 12, 2019 9:33 am
Sounds like a more extreme version of something I experienced on one of our cars recently.
With the car in the air everything felt tight, just like you say. But your car generates a lot more force than your body can muscling those front wheels around to check for play.
In my case I finally traced it down to a faulty tie rod end on the drivers side.
In your case this may make a lot of sense as well. The play on ours was almost completely imperceptible. But with a new Lemforder part in there our darting symptom is gone. Takes a while to manually get the alignment right on but you’ll get there eventually.
June’s suggestion of subframe bushings is also probable.
2001 V70XC 135k
2004 V70 AWD 130k
2004 XC70 278k
2006 XC70 150k
