99 s70 abs check engine light Topic is solved
royzmvslogin
Year and Model: 1999 s70
Post by royzmvslogin »
this is my first trip to your forum there seems to as much or more misinformation than good information on other sites one place says you can test sensors with ohm meter other place says these should be tested with wheels turning on ac volts tried ac check got 0 volts tried ohm test got 0 should it be assumed sensors are bad
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You can test them both ways.
If you get 0 Ohms when wheel is stationary or O Volts when wheel is rotated ...then that sensor is dead.
I take it that you measured that directly on sensor's connector.
Please use interpunction signs in writing,since it is a bit hard to read what you wrote.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
yes I did. thank you for the reply misha.
misha
Post by misha »
There was some topic here on MVS about a week or so about abs sensors.
I think that they mentioned that cheap aftermarket ones will not work.
If you go aftermarket...go with reputable brands.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
checking on amazon some low some high. thanks for response.
misha
Post by misha »
You will need ATE sensors if the car is equipped with ATE abs system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
it is . thank you.
Has thanked: 1614 times
Been thanked: 4078 times
Disconnect the sensor at the suspension strut. Pull the plug apart, and ch3ck the resistance at that plug, it should be 1200-1500 Ohms. They rarely go bad, other than damaged wires. Sometimes the tone ring hits them which will causeABS errors
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Most likely a front left ABS sensor fault will be a ABS module error.
There's a couple good write-ups here on how to do a top class solder repair to the ABS circuit board or just send it to Matty Moo at Midwest ABS.
Misha and all others..thanks for reminding folks that we keep our post standards of writing And punctuation high here on MVS.
