IPD sale Volvo Parts
Did you know? 🤔
99 s70 abs check engine light Topic is solved
royzmvslogin
Year and Model: 1999 s70
Has thanked: 0
Been thanked: 0
United States of America
royzmvslogin
Post by royzmvslogin » Sat Feb 23, 2019 3:18 pm
this is my first trip to your forum there seems to as much or more misinformation than good information on other sites one place says you can test sensors with ohm meter other place says these should be tested with wheels turning on ac volts tried ac check got 0 volts tried ohm test got 0 should it be assumed sensors are bad
misha
Has thanked: 27 times
Been thanked: 88 times
Serbia
misha
Re: 99 s70 abs check engine light
Post by misha » Sat Feb 23, 2019 3:46 pm
You can test them both ways.
If you get 0 Ohms when wheel is stationary or O Volts when wheel is rotated ...then that sensor is dead.
I take it that you measured that directly on sensor's connector.
Please use interpunction signs in writing,since it is a bit hard to read what you wrote.
'97 850 2.5 20v /fully equipped/ Motronic 4.4 / polar white wagon
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
Has thanked: 0
Been thanked: 0
royzmvslogin
Post by royzmvslogin » Sat Feb 23, 2019 3:49 pm
yes I did. thank you for the reply misha.
misha
Serbia
misha
Re: 99 s70 abs check engine light  Topic is solved
Post by misha » Sat Feb 23, 2019 3:57 pm
There was some topic here on MVS about a week or so about abs sensors.
I think that they mentioned that cheap aftermarket ones will not work.
If you go aftermarket...go with reputable brands.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
Has thanked: 0
Been thanked: 0
royzmvslogin
Post by royzmvslogin » Sat Feb 23, 2019 4:08 pm
checking on amazon some low some high. thanks for response.
misha
Serbia
misha
Post by misha » Sat Feb 23, 2019 4:10 pm
You will need ATE sensors if the car is equipped with ATE abs system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
royzmvslogin
Has thanked: 0
Been thanked: 0
royzmvslogin
Post by royzmvslogin » Sat Feb 23, 2019 4:12 pm
it is . thank you.
Has thanked: 191 times
Been thanked: 603 times
Trinidad & Tobago
Post by abscate » Sat Feb 23, 2019 7:30 pm
Disconnect the sensor at the suspension strut. Pull the plug apart, and ch3ck the resistance at that plug, it should be 1200-1500 Ohms. They rarely go bad, other than damaged wires. Sometimes the tone ring hits them which will causeABS errors
Year and Model: Lots
Has thanked: 4 times
Been thanked: 94 times
Australia
Post by precopster » Sun Feb 24, 2019 4:49 am
Most likely a front left ABS sensor fault will be a ABS module error.
There's a couple good write-ups here on how to do a top class solder repair to the ABS circuit board or just send it to Matty Moo at Midwest ABS.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Trinidad & Tobago
Post by abscate » Sun Feb 24, 2019 5:14 am
Misha and all others..thanks for reminding folks that we keep our post standards of writing And punctuation high here on MVS.
