Hello,
Every time I press on brake pedal , dashboard bulb for my front lights goes on. If I turn on the lights, light bulb will go on as normal, and then when I press brake pedal, light will go off while my break pad is engaged.
I know that sometimes right back brake tail light will go off, and I would have to remove light bulb and put it back again to make it work again.
Also I dont know if this is connected , but every time I press brake pedal , there is double clicking noise coming from the area around my transmission stick /dashboard area under radio.
Volvo 240 wagon 1993 is my car.
Did anyone has any advice on how to troubleshoot this?
Thank you
Why is dashboard light bulb linked to my brake pedal?
volvo240student
- Year and Model: 1993 240
- Has thanked: 6 times
- June
- Has thanked: 523 times
- Been thanked: 261 times
The clicking is the shift lock mechanism. It's likely just getting tired. The light indicator usually means a bulb is out. So likely the car is telling you a light is out. During my 89 740 ownership I had havoc with a taillight on one side until the taillight circuit board was replaced. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Bad ground or poor bulb connection to the contact plates on taillights can cause this. I bet you have a dim brake light and one of the park lamps up fronts comes on when brakes are applied. You may not see it unless it is dark. If the brake light filament and the park light filament meet at the ground on body of bulb. If the ground is not good then the brake light current goes through the taillight filament and then back down the line to the front park light bulb through its filament to ground. This powers the park light circuit and turns on that lamp. I'm surprised the bulb failure lamp is not on.
volvo240student
yes, there is issue with contact plates on the right taillight , that brake light goes off all the time. I have to wiggle the bulb holder socket to make it work. But even when i set it up to work, I still get dash light goes on when engaging the brake.
Should I try to replace only bulb holder socket or whole new assembly?
volvo240student
You nail it! It is the failure lamp bulb on dashboard that goes on once I engage brake or turn on light. Silly me was thinking that is regular “ light is on “ dash sign.jimmy57 wrote: 25 Feb 2019, 18:57 Bad ground or poor bulb connection to the contact plates on taillights can cause this. I bet you have a dim brake light and one of the park lamps up fronts comes on when brakes are applied. You may not see it unless it is dark. If the brake light filament and the park light filament meet at the ground on body of bulb. If the ground is not good then the brake light current goes through the taillight filament and then back down the line to the front park light bulb through its filament to ground. This powers the park light circuit and turns on that lamp. I'm surprised the bulb failure lamp is not on.
I tested the front park light and they don’t go on when I press pedal.
It looks like that passenger side tail light and brake are working all the time. Also one of the connectors melted the tailgate box plastic.
I have switched the sockets with driver side and replace the bulbs to make sure that is not issue.
Is there something I should do to test/inspect taillights assembly or wiring for to see what is other potential issue or just get replacement taillight assembly?
volvo240student
Update :
I have replaced tail light assembly and rotate sockets and my brake light on passenger side will still not go on...
Position back light will go on when I turn on lights so there is power getting to the socket.
Do you have any advice on what to look next ?
- 1096 Views
Last post by Nellys80
- 11 Replies
- 618 Views
Last post by MoVolvos
- 4133 Views
Last post by silentcircuit
- 386 Views
- 595 Views
