Any tips on diagnostic steps on the headlamp washers not working. I have the ones that are within the bumper and then push out squirting fluid on the lights only- no wipers.
To me they are ineffective but since it’s too cold to play golf up here in the Northeast I’ll spend my time addressing this.
I have to add that the washer fluid is full and still not working.
Thanks
2005 S60 2.5T
Headlamp washer
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
My 2006 has the headlamp washer, also. They stopped working suddenly with a big leak of washer fluid - I was topping up as it was low. There are two pumps, one for the headlamps and one for the windscreen.
Perhaps your headlight pump has failed (not leaking) or perhaps is not getting power.
My mechanic saved me the cost of a new headlamp pump by plugging the hose to the headlamp pump as the pump was very rusted. I plan to fix it at some point, but it is low on priorities for me (although I do love the feature).
You will need an assistant to turn the headlight switch on and wash while you listen to see if both p7mps work
Golf is great this time of year, but the greens are fast. You always get a good lie in frozen bunkers
537playing
Hmm. You mention headlight switch. Which position should it be on or does it make a difference?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I'm in the midst of cleaning out the garage in prep of moving back to GA. I've got a spare pump if you need it for the price of the postage. Do your windshield washers pump water OK?
537playing
Thanks. Windshield pump is fine
- RickHaleParker
- Been thanked: 978 times
The fuse and relay for the High Pressure Headlight Washer is in the engine bay fuse box.
Active
Past
Past
537playing
Are you saying that I should replace the relay first?
EngineeringBloke
Check headlamp washer fuse (15).
Switch the windshield washer relay with the headlamp washer relay and see if the fault moves - bad relay.
Try to see if the headlamp washer pump is getting power.
You trouble shoot electronics backwards...look for voltage at the component , then work your back to find where it is and why the circuit is broken.
- 1938 Views
Last post by Rattnalle
- 277 Views
Last post by MoVolvos
- 15 Replies
- 8671 Views
Last post by volvolugnut
- 36 Replies
- 24675 Views
Last post by StickyPocket
- 3123 Views
Last post by Mr. Detail
