IPD sale Volvo Parts
Did you know? 🤔
check engine light and throttle body Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
chris11211
Year and Model: 2006 s60
Has thanked: 5 times
United States of America
chris11211
Post by chris11211 » Tue Feb 26, 2019 5:04 pm
Hello
This is my first car which was gifted to me by my aunt, and it is an 06 S60 2.5T with 156000 miles.
My problem is this check engine light that refuse to leave. The codes that come up are P0170 and two P0101 from the computer. In response, my mechanic changed the MAF twice, but after 15 minutes of driving the light comes back on for both sensors and he returned the original, so its not the MAF. There is also no air leaks or damaged electrical wiring problems according to the mechanic.
So the next thing I did was to check the throttle body, and I discovered a ring of dirt all over the edges. So I am wondering if it's either worth it to attempt to clean the ETB or just replace it in order to clear the check engine, because I think this is literaly the only problem left with the car, and I cannot pass inspection with it on.
I have experienced stalling while starting the car, while accelerating the car "jumps" on occasion, large fuel consumption, and rumbling while the gear is in reverse or not in park/neutral. Also I replaced the air filter for an OEM one, and code were cleared before.
So what should I do from here, clean the Throttle body, just replace it, or is it something else?
Below is some picks I took of the butterfly flap.
https://photos.app.goo.gl/zLHfbQeBPGRunLHu5
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 15 times
chrism
Re: check engine light and throttle body  Topic is solved
Post by chrism » Tue Feb 26, 2019 5:24 pm
Replacement throttle bodies don’t come cheap - no need to replace, at least not yet.
Clean it with some spray carberator cleaner and a toothbrush. When spraying the carb cleaner try to hold the throttle body in an orientation that doesn’t allow the carb cleaner to run into the holes for the butterfly pivot shaft.
Your aunt is a nice lady!
These users thanked the author chrism for the post:
chris11211
Has thanked: 149 times
Been thanked: 474 times
Trinidad & Tobago
Post by abscate » Tue Feb 26, 2019 5:40 pm
It's worth cleaning, and also posting up your throttle body part number in case we have some folks nearby who have a spare to test and try. Just remind them to take the R train, not the R Volvo.
These users thanked the author abscate for the post:
chris11211
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
chris11211
chris11211
Post by chris11211 » Tue Feb 26, 2019 5:47 pm
The part number is 30711553. But will it solve the check engine problem I am having? Running out of avenues and time to fix it, also my temp inspection sticker expired.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 13 times
Been thanked: 10 times
XC70Rider
Post by XC70Rider » Tue Feb 26, 2019 6:45 pm
chris11211 wrote: ↑
Won't know until you give it a cleaning.
My faulty ETM was throwing the P0101 alone. The ECM wasn't pointing at the ETM soley but was telling me I had an air leakage. The internal plastic gears were slightly worn out so it couldn't adjust the valve properly. I replaced many of parts and did a good cleaning before I threw on a new ETM to solve the issue.
https://www.matthewsvolvosite.com/forum ... t=ecm+121b
As mentioned earlier try cleaning it first because they aren't cheap.
These users thanked the author XC70Rider for the post:
chris11211
Trinidad & Tobago
Post by abscate » Tue Feb 26, 2019 8:17 pm
To properly diagnose the throttle body you need a program called VIDA And an afternoon to run the tests on the throttle body, you can’t test it with standard equipment.
The folks who have 10,000 hours in invested in broken cars can diagnosis by symptom, but the rest of us can’t.
Try the cleaning and see it helps
chris11211
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
chris11211
chris11211
Post by chris11211 » Thu Mar 07, 2019 7:10 pm
Thanks guys. After driving it around for hours, the p0101 and p0170 check engine codesdoes not show up anymore after i cleaned the throttle body.
I also managed to pass inspection.
P.S Leave it to Volvo to put a throttle body in the most awkward position.
