'04 XC 70 Lower Control Arm Bolts --Torque Specs.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Anybody have access to lower control arm bolt(front) torque specs for an '04 XC 70? Hope to do the job tomorrow. Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
The write-up I read says these are one-time torque to yield fasteners that should be replaced with new. 65 Nm + 90 degrees for the front bolt and 105 Nm + 90 degrees for the rear bolt/nut.
Scroll to nearly the end of this document:
http://www.v70xc.com/0/resources/how-to ... shings.pdf
I wonder how many people actually replace with new. I didn't ;(
- E Showell
Thanks Chris
'95 855 auto (sold)
'95 855 auto (sold)
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Valuable info.
Is it necessary to lift the engine out of the mount? Or is this the complicated factory technique?
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
I did this job with new fasteners. You don't need to lift the engine from the mounts or drop the subframe to access the front bolts, as the space is tight i did use an 15mm offset combination spanner it worked great but you won't be able to torque the fasteners to spec that way.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
chrism
As I recall when I did this on my V70 (it was several years ago) I was able use to my floor jack and a block of wood under the oil pan and just lifted the engine a TINY bit - like whatever I thought the rubber motor mounts would allow - and that gave me enough room to get after the bolts.
- 11 Replies
- 1967 Views
Last post by ericmci
- 1721 Views
Last post by kosh_al
- 3543 Views
Last post by gibbi42
- 1299 Views
Last post by Nevada1906
- 4693 Views
