Did you know? 🤔
S60 t5 2012 purge valve
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
Brianvzyl
Year and Model: 2014
Has thanked: 0
Been thanked: 0
South Africa
Brianvzyl
Re: S60 t5 2012 purge valve
Post by Brianvzyl » Tue Mar 05, 2019 1:47 pm
Thank you SuperHerman.
I will check to see if i can find the number on the vehicle name plate.
Brianvzyl
Has thanked: 0
Been thanked: 0
South Africa
Brianvzyl
Post by Brianvzyl » Sun Mar 10, 2019 5:45 am
Hi jimmy57.
Okay i stripped out the back wheel arch lining to see where this breather/vent pipe is. I found the vent pipe it seems to be open. I gave it a blow with the fuel cap open. It made the same knocking noise and build up pressure. As soon as i stoppe blowing it then released the pressure back out the vent pipe mak8ng the same knocking noise. So i am now very confused as i would think that a straight vent pipe should vent without the knocking noise.unless it goes through a pump.
Any advice from here on?
Thanks
Brian
