1998 V70 NA
Need to change O-ring and seal on lower (output) auto trans fluid cooler line. If I were to not drain at the trans, but instead removed the lower cooler line at the radiator, it would seem that I would only lose, maybe, 2 quarts of fluid. Might I be correct? And, any reason why this might be a really stupid idea?
Thanks, DaleL
changing lower trans cool line seals Topic is solved
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Look closely at the bottom line, you will find that it is downhill to the sump. There should be very little ATF in the radiator with a cold engine.
Once you start the engine, there will be close to a quart of ATF in the radiator and lines, I do not know how fast the ATF will flow back into the sump after shut off.
Klaus
- 36 Replies
- 21088 Views
Last post by Achilles
- 1326 Views
- 684 Views
Last post by Mike Langlois
- 11 Replies
- 3758 Views
Last post by dang5002
- 528 Views
Last post by Sveedy
