IPD sale Volvo Parts
Did you know? 🤔
changing lower trans cool line seals Topic is solved
dalel
Year and Model: 1998 V70
Has thanked: 1 time
United States of America
dalel
Post by dalel » Mon Mar 04, 2019 7:47 am
1998 V70 NA
Need to change O-ring and seal on lower (output) auto trans fluid cooler line. If I were to not drain at the trans, but instead removed the lower cooler line at the radiator, it would seem that I would only lose, maybe, 2 quarts of fluid. Might I be correct? And, any reason why this might be a really stupid idea?
Thanks, DaleL
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 3 times
Been thanked: 7 times
Klausc
Re: changing lower trans cool line seals  Topic is solved
Post by Klausc » Mon Mar 04, 2019 9:31 am
Look closely at the bottom line, you will find that it is downhill to the sump. There should be very little ATF in the radiator with a cold engine.
Once you start the engine, there will be close to a quart of ATF in the radiator and lines, I do not know how fast the ATF will flow back into the sump after shut off.
These users thanked the author Klausc for the post:
dalel
Klaus
