Hi everyone, it's been a long time since I have been here. I bought a new car so haven't been driving the 2000 V70XC. But I am giving it away to a friend who needs a car and I need to get it running. I hope you can help.
Last year I took out the AWD transfer case (whew!). What a job. It ran fine but now there is a problem. The drive shaft slides in and out of the transmission case and can disengage from the transmission drive gear. What is supposed to hold the drive shaft in? Is the bearing that is in the shaft support near the wheel supposed to be pressed onto the shaft? Does that keep the shaft from moving in and out?
Thanks for all help in advance.
I'M BACK!!! lol. need help, of course. (AWD removal) Topic is solved
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
I'm going to answer my own question. when I removed the angle gear last year I decided to put in a new axle and CV joint assembly. It was not expensive. The bearing on the new assembly has separated from the axle, allowing the shaft to slide in and out. In other words, I got a cheap-ass part that failed after a few thousand miles.
So, this is a good lesson that even on an 18 year old car you do not want to put cheap CarQuest parts in it.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
