[2001 V70 2.4T] Hiccup in power steering / alternator when splashing through water
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Twice in the past month, I have experienced a brief hiccup in power steering and alternator/electrical charging performance after splashing through standing water. Things typically go back to normal on their own within 30 seconds, or immediately if I rev the engine. I don't have a splash guard installed under the engine, but then again I've never had one in the 3+ years I've owned this car. I know I've splashed through some big puddles before, and this is the first time I've had this experience. Is this type of behavior expected when the accessory belt area gets hit with a splash of water, or should it be able to handle such a situation without a loss in performance?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Check the belt tension and condition. The water maybe lubricating or hydroplaning the belt just enough to cause slippage.
Active
Past
prwood
Post by prwood »
RickHaleParker wrote: 11 Mar 2019, 10:54 Check the belt tension and condition. The water maybe lubricating or hydroplaning the belt just enough to cause slippage.
Is there a rule of thumb for auxiliary belt tension? In the auxiliary belt/tensioner replacement instructions, VIDA just says "Check the rotation of the belt and the operation of the belt tensioner," with no specifics. Visually it looks fine, though I have a suspicion it's been contaminated by a chronic power steering fluid leak at the reservoir.
The current belt (Duralast brand) has 11,741 miles on it, and the current tensioner (also Duralast brand) has 29,910 miles.
Cars I've owned:
RickHaleParker
prwood wrote: 11 Mar 2019, 11:49 I have a suspicion it's been contaminated by a chronic power steering fluid leak at the reservoir.
Rub the belt with a paper towel, see if the paper towel picks up any Power Steering Fluid.
Power Steering Fluid would lower the Coefficient of friction, that would explain the symptoms.
Active
Past
Has thanked: 1610 times
Been thanked: 4068 times
The serpentine belt tension is set by the tensioner, unlike the lever job you had to do on Dads Oldsmobile.
Thats why the belts last forever, too.
Im guessing its oily and the water/oil is making it slip.
Preventative Maintenance Model - replace serp belts at 60k/5 years. My 1999 manual says 'inspect' at 60k. WTF?
prwood
Post by prwood »
Once I eliminate any sources of belt contamination, would I need to replace the belt, or would cleaning it be sufficient?
I'm assuming that using brake cleaner or other harsh chemicals on the belt would be a bad idea. For cleaning it, I had two ideas:
1. Start the engine, then hit both sides of the belt and all pulleys with sprays of soapy water (mild detergent like Dawn) until everything is wet, then follow up with sprays of clean water to rinse, and let it spin itself dry.
-or-
2. Remove the belt, wash it in a tub of soapy water, rinse in clean water, air dry or dry with compressed air. While belt is off, spray down pulleys with brake cleaner to remove any contamination.
Cars I've owned:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Could it be some exposed wire or even electrical module? Also look at the ECM cover, especially at the bottom, those covers are not always well fitted and may have a gap (@17:00 into the video www.youtube.com/watch?v=Kg-lsya-LiY).
May try to source that engine shield skid plate, I use it and it keeps the ice off the belts/pulleys in winter time as well, and also protects the corrosion prone power steering lines to the rack for 01-03 years https://www.ipdusa.com/products/11463/1 ... 0-v70-xc70
RickHaleParker
prwood wrote: 12 Mar 2019, 07:34 I'm assuming that using brake cleaner or other harsh chemicals on the belt would be a bad idea.
Simple Green.
You could try the degreaser at a car wash, then pressure wash the whole engine bay. Get all the crap that may recontaminate the belt.
Active
Past
prwood
Post by prwood »
oragex wrote: 12 Mar 2019, 07:54 Could it be some exposed wire or even electrical module? Also look at the ECM cover, especially at the bottom, those covers are not always well fitted and may have a gap (@17:00 into the video www.youtube.com/watch?v=Kg-lsya-LiY).
Could *any* exposed wire in the engine bay cause this problem? I'll take a look, but any time that I've worked with bare copper I've always wrapped it thoroughly in electrical tape.
I've only ever removed the top lid on the ECM box, never the plastic box that surrounds it; however, it is probably worth a look.
What is the purpose of all the tinfoil in the engine bay of the car in that video?
oragex wrote: 12 Mar 2019, 07:54 May try to source that engine shield skid plate, I use it and it keeps the ice off the belts/pulleys in winter time as well, and also protects the corrosion prone power steering lines to the rack for 01-03 years https://www.ipdusa.com/products/11463/1 ... 0-v70-xc70
It's on the long list... :-)
Cars I've owned:
oragex
Post by oragex »
I wrapped the foil over the A/C lines, the A/C cools just not at 100%, the foil may help a tad insulate the lines from the engine heat
